Just pondering back on the fitting of it, is it right that all that holds it tight on is one circlip where the lever fits on?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
yes
Gear shift Shaft | SV_Leeds | SV Talk, Tuning & Tweaking | 0 | 26-03-09 09:03 PM |
Insurance are trying to shaft me! Please help. | Dave20046 | Bikes - Talk & Issues | 28 | 03-10-08 08:53 PM |
Oil leak output shaft help | mattc | SV Talk, Tuning & Tweaking | 3 | 05-05-08 05:48 PM |
Gear conection rod/shaft wanted ASAP!! | rayuk81 | Stuff Wanted | 0 | 24-08-07 11:10 PM |
Shaft Vs Chain | NAPA121 | Bikes - Talk & Issues | 12 | 24-03-06 11:45 PM |
