Old 19-04-11, 08:07 PM   #1
warmshed
Default Removing front mudguard?
Just a quick one, do you need to remove the front wheel to take the mudguard off like the Haynes book says? Got a fender extender and want to fit it but it will be a bit of a fiddle with just the side stand to get the wheel off. Thanks, Dave
Old 19-04-11, 08:12 PM   #2
mark_sv650s
Default Re: front mudguard
No you do not need to remove the wheel to get the front mud guard off.
Old 19-04-11, 08:47 PM   #3
warmshed
many thanks, don,t need to allow so much time to do it. Great.
Old 19-04-11, 08:48 PM   #4
FG1
Put a bit of masking tape on it so you don't rub the paintwork on the forks as you pull it out...
Old 20-04-11, 07:30 PM   #5
leebex
Default Re: Removing front mudguard?
When refitting the mudguard, i also found it helpful to stick the mudguard nuts to the inside of the mudguard with some double sided tape, as its a tight fit to get your hand in there.
Old 20-04-11, 09:09 PM   #6
warmshed
Many thanks, will fit the extenda over the weekend, armed with double sided and masking tape!
Removing Front Mudguard Screws I'm_a_Newbie SV Talk, Tuning & Tweaking 5 10-08-09 10:18 AM
K2 Front Mudguard Barney Stuff Wanted 0 08-08-09 07:54 PM
Removing the mudguard - front wheel off? Tiger 55 SV Talk, Tuning & Tweaking 14 29-08-07 10:54 AM
Front mudguard djb Stuff Wanted 0 30-08-06 11:13 AM
Removing front mudguard to fit extenda branny SV Talk, Tuning & Tweaking 10 10-08-05 12:37 PM
