Old 20-04-11, 08:56 AM   #1
muzikill
muzikill's Avatar
Default Front fork stanchions repair/refurb thread
Here they are, they were covered in rust spots but i cleaned them up using a light scourer and autosol. Ive posted the both sides the first pic (the right one looking as if sitting on the bike) is the one that 'may' have a torn seal. I say may as i push the front suspension down and back up there are signs on fork oil around the base of the stanchion but only slight. The left side fork doesnt have any problems apart from the same 'look' as the right after clean up. I expect more work is necessary as these 'nicks' will only rip the fork seals already there or if they were replaced again! Ive looked around on the net and i know that new stanchions will be around £200 for the pair - It pays to look after you front suspension btw...
I can still feel 'nicks' on the stanchions and i am looking for more advice on how to clear up this matter as i dont know how this is going to affect it when it goes in for its mot.
Old 20-04-11, 10:11 AM   #2
mikerj
Default Re: Front fork stanchions repair/refurb thread
If it is pitted in the swept area of the stanchion then the seals will last no time at all. It is possible to bodge things by using fine wet and dry to remove any high spots and then fill the pits with epoxy and smooth down again afterwards. It's very time consuming if there are lots of small pits though, and it's not a permanent repair IME.
Old 20-04-11, 10:16 AM   #3
I think someone has looked into hard annodization recently for similar reasons.
I can't find the thread, but someone will be able to point you
Old 20-04-11, 10:42 AM   #4
warmshed
The best/only way to repair them is to have then ground and hard chrome plated. Look at the back of any motorcycle publication and you should find a number. Had my Velocette forks done about 25 years ago and they are still like new. not cheap but better than replacements. One such Place is http://forkrechroming.4t.com/ but look ant phone round for the best place and price.
Old 20-04-11, 05:20 PM   #5
Hit them with 1200 emery and plenty silicone lube, make sure you get all the abrasive off when you're done.
Old 20-04-11, 05:43 PM   #6
muzikill
muzikill's Avatar
I take it the silicon lube is used along with the emery? I also used fine steel wool but those nicks were still there . .
Old 20-04-11, 05:47 PM   #7
Yes. Go around tube, the fine scratches you leave will hold an oil film.
Old 21-04-11, 06:23 PM   #8
muzikill
muzikill's Avatar
Got the stuff today bud, will give it a whirl tomorrow! - i will let you know. once again ta for the advice!
Old 21-04-11, 06:25 PM   #9
muzikill
muzikill's Avatar
Maybe you should read the wording on that ad! - certainly wouldnt be using them.
Old 21-04-11, 06:41 PM   #10
Spanner Man
Good evening all.
When I was up on that neck of the woods, I used their services on several occasions. They were very good.
Rather than rechroming, I prefer to use ABE stanchions. They're excellent! What's more, they're hard chromed too. Reckon on around £90 each.
ABE can be contacted on; 020 8858 9052.
Cheers.
P.S. I like the tongue in cheek advertising the Northern lot use. I would have thought the Cowboy would have given it away
Spanner Man
Pointy fork Sliders/Stanchions Berlin Stuff Wanted 14 02-12-10 09:13 PM
Wanted: Fork stanchions or complete forks for Curvy Sid Squid Stuff Wanted 1 25-11-10 11:35 AM
Can you repair front fork corrosion? robertjp SV Talk, Tuning & Tweaking 45 23-01-09 10:33 AM
Fork stanchions, indicators. instigator Stuff Wanted 2 02-09-06 08:45 PM
Front Forks Refurb The Wolf SV Talk, Tuning & Tweaking 4 22-10-04 06:09 PM
