Old 23-04-11, 06:34 PM   #1
daveyrach
Default Broken Top Yoke.
So i was adjusting my steering head bearings today and all went fine when i was putting it back together i was torquing up the top tolk clamp bolts and before i got to the 23nm specified by haynes this happened:-
Attachment 8964
Does any one know if is safe to ride in this condition or do i need a new top yolk?
My theory is that the bottom clamp is OK and the clip on bar is also gripping the fork which in turn is attached to the top yolk. So i think it will be OK and could i get away with aralditing it or summit.
If not has anyone got a top yolk kicking around FOC if poss as i need the bike to cummute but i am not at work till 3rd May now.
Old 23-04-11, 06:37 PM   #2
toxic
Default Re: Top Yolk Problem!
Dangerous to ride it like that!!
Fork could flex under heavy braking and possibly damage lower yolk.
Old 23-04-11, 06:40 PM   #3
daveyrach
Bugger!
Old 23-04-11, 06:43 PM   #4
Yeah, change that ASAP. Yokes are pretty cheap, try PM Berlin or husky03
Old 23-04-11, 06:46 PM   #5
daveyrach
F**k it, why do these things happen when you least afford them. How easy is it to change over ignition assembly or does it need drilling or something silly
Old 23-04-11, 06:47 PM   #6
Bit of a pain in the tits, it is security torx fitting.
Old 23-04-11, 06:49 PM   #7
husky03
nobber! lol-i'll check and see if theres one in the garage -if so you cover postage and its yours mate
h.
Old 23-04-11, 06:50 PM   #8
daveyrach
Thats the ones with the little nipple in the middle isn't it? That would be a pain as i have normal torx bits.
Do you know what size and they are not sheer bolts are they?
Old 23-04-11, 06:51 PM   #9
daveyrach
h.
Your a life saver mate, let me know ASAP, and i will def cover postage and enough for a couple of beers.
Old 23-04-11, 06:53 PM   #10
You can center pop the nipple in middle and drill it, once you got to 2mm drill or so just give it a whack and nipple will be gone so you can use normal torx.
Top yoke? SUPERSTARDJ01 Bikes - Talk & Issues 2 07-11-09 07:24 AM
gpz yoke Airwolf Bikes - Talk & Issues 3 23-03-09 10:16 PM
Wow, I want this yoke!!!!!!!! plowsie SV Talk, Tuning & Tweaking 13 23-01-09 04:50 PM
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
