Old 24-04-11, 01:57 PM   #1
muzikill
muzikill's Avatar
Default Exhaust cleaning. my version
Thats the stuff to use! - shine it up using autosol and a cloth and your sorted. Warning! (you will do a lot of rubbing)
Old 24-04-11, 02:39 PM   #2
LJH
Default Re: Exhaust cleaning. my version
Use a wire wool, much better!
Old 24-04-11, 06:16 PM   #3
muzikill
muzikill's Avatar
I always thought you should keep the wire wool to a minimum. After all these are chromed parts!
Old 24-04-11, 06:24 PM   #4
Header pipes are polished S/S not chrome
Old 24-04-11, 06:25 PM   #5
LJH
The downpipes are chromed? Thought it was just stainless steel.
Old 24-04-11, 06:25 PM   #6
LJH
Old 24-04-11, 06:26 PM   #7
daveyrach
Tis S/S
Old 24-04-11, 06:32 PM   #8
Yep S/S = shiny stuff
Old 24-04-11, 07:09 PM   #9
muzikill
muzikill's Avatar
stainless steel! oh well steel wool it is then
Old 24-04-11, 07:19 PM   #10
Dizzy Blonde swears by that barkeepers friend.. so I got some..
tis good stuff..
Cleaning Exhaust downpipes andrewsmith Bikes - Talk & Issues 18 06-10-11 07:44 PM
Cleaning Exhaust DANINPLYMOUTH SV Talk, Tuning & Tweaking 0 12-09-09 08:25 PM
Scottoiler - new version v old version mattb200 Bikes - Talk & Issues 4 20-05-09 06:31 PM
Cleaning S/Steel exhaust StreetHawk Bikes - Talk & Issues 9 01-04-08 04:21 PM
Cleaning exhaust? FreshAL SV Talk, Tuning & Tweaking 4 17-01-06 05:28 PM
