Old 26-04-11, 09:41 AM   #1
DaveW_42
DaveW_42's Avatar
Default Disaster! Tap snapped - exhaust stud.
Hey everyone,
Snapped both bolts off on the front downpipe where they go into the casing. Drilled and tapped one side perfectly fine, drilled the other and got to within about 4mm of finishing the tap, when the damn thing snapped on me!
No matter what I do, I can't get it to twist at all with needlenose pliers, there's nothing left outside the hole to grip with molegrips and I spent ages trying to drill it out to no avail. Eventually decided to stop before I made it any worse...
Any suggestions?
D
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings.
DaveW_42 is offline   Reply With Quote
Old 26-04-11, 09:45 AM   #2
Default Re: Disaster! Tap snapped
weld a nut to it? or is there not enough left?
Old 26-04-11, 09:45 AM   #3
DaveW_42
DaveW_42's Avatar
nothing left - it's flush to the casing. Everything crumbled when I got the grips on it
Old 26-04-11, 10:05 AM   #4
Gazzaleachie
Hi,
I have drilled taps out with a cobolt drill bit with plenty of suds but i normally mount in my milling machine as i can control the pressure and speed alot better than a hand drill.
Gaz
Old 26-04-11, 10:21 AM   #5
danf1234
I have done this twice on older bikes - And yes you are correct it is a disaster.
Both times I have enlisted professional help in the form of a proper local engineering firm.
Old 26-04-11, 10:22 AM   #6
DaveW_42
DaveW_42's Avatar
Hmmmmm... Everyone is saying the same thing too. Looks like I might just get a replacement head, drop the engine out and swap over...
Lucky there's another 4 day weekend coming up!
Old 26-04-11, 10:30 AM   #7
DaveW_42
DaveW_42's Avatar
Old 26-04-11, 10:55 AM   #8
timwilky
timwilky's Avatar
Default Re: Disaster! Tap snapped - exhaust stud.
spark erosion. You need to find a man that can.
Not Grumpy, opinionated.
Old 26-04-11, 11:00 AM   #9
DaveW_42
DaveW_42's Avatar
Cheers Tim. Looked at that too. Would prob have to drop engine out anyway, then (the place I found) it costs anything up to £100. If I'm paying that out anyway and dropping the engine, I may aswell try and find a replacement head for less and just swap it over myself.
One of those times, you get a nice weekend and start your job list, then by the end of it, have a completely new jobs list to tackle too.
Old 30-04-11, 03:17 PM   #10
all the gear
just checked mine out and the thread is 25mm deep ,as the hole is in a raised area of casting you could easily afford to cut the alloy back by 5mm exposing the tap sufficient to get some grips on it ,if your tap extractor doesn't work.
You would still have a good 15mm of thread allowing for the fact that the last couple of mm of any blind hole can't be tapped.
Broken exhaust stud. barwel1992 SV Talk, Tuning & Tweaking 17 10-01-11 09:12 AM
Farrrk Snapped Exhaust Header Stud Bolt 21QUEST SV Talk, Tuning & Tweaking 25 02-08-08 09:40 PM
Snapped Exhaust stud! spacehog SV Talk, Tuning & Tweaking 4 22-05-08 08:21 PM
Removing Exhaust a Stud Grinch SV Talk, Tuning & Tweaking 50 28-02-08 11:08 PM
exhaust stud dirtydog SV Talk, Tuning & Tweaking 13 14-02-06 04:07 PM
