Old 27-04-11, 05:48 PM   #1
Speedy
Default tyres 120/70/17 vs 120/60/17
In the middle of getting all my parts needed for my front end swap....
Wanna pick all your brains with regard to the effects of going with the standard GSXR tyre size or staying with the SV standard size.
Obviously I know the rake/trail is affected by changing the forks from SV, especially noticeable on mine being a naked, (different fork offset to the S models) to GSXR, what I don't want is a twitchy front end (ooh err) at high speed....so should I use the 70 profile tyre to effectively raise the front ride height back up slightly....(GSXR slightly shorter fork length than SV).
Also, the rolling radius will be different using the 70 profile to stock, will I need a speedo healer?
Cheers!
Old 27-04-11, 06:31 PM   #2
warmshed
Default Re: tyres 120/70/17 vs 120/60/17
Don't know about the rest but the rolling radius will be greater but speedos normally over read so you may find it more accurate.
Old 27-04-11, 06:47 PM   #3
daveyrach
I have a 120/70 tyre on a std SV front end, i find the bike is much keaner to lean in to corners and seems to lean further quicker if that makes sense.
Old 27-04-11, 07:02 PM   #4
Berlin
Use the 120/70. It's the tyre the Sv should have on from the start. The only other bike I know of that uses a 120/60 is the early R6 and all the folks that run one now use a 120/70 tyre.
As stated the speedo will be more accurate.
Old 28-04-11, 10:18 AM   #5
Speedy
Ok, thanks everyone!
That's made that decision then!
What Tyres To Put On? Sticky Tyres. SV650R Bikes - Talk & Issues 33 22-10-09 01:50 AM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
New Tyres! Wonderful wonderful round new Tyres!! Kate Tyres 28 14-07-05 10:27 PM
Tyres you have... tyres you gettin'? Daz TOTALSV Ireland 6 04-02-05 10:34 PM
Tyres oh tiring tyres 454697819 SV Talk, Tuning & Tweaking 15 13-10-04 08:40 PM
