Old 27-04-11, 09:19 PM   #1
hannakournikova
Default Dust seals -brakes, where from?
Hi guys, where could I find 4 dust seals for a curvy sv650.
Old 27-04-11, 09:21 PM   #2
hongman
Default Re: Dust seals -brakes
Wemoto
Robinsons foundry
eBay
Google
Old 27-04-11, 09:34 PM   #3
depends if you want OEM or patterns
Patterns- Wemoto I've got a pattern set and they're spot on
OEM- main dealers, could be a wait tho as parts are being affected due to the ongoing disaster in Japan
Old 27-04-11, 09:45 PM   #4
hannakournikova
Wemoto- don't list them separately
Robinsons foundry- will check now
eBay - won't split the kit
Google - load of useless and twaddle but a link to this forum
Old 27-04-11, 09:47 PM   #5
the dust seals and brake seals need to be changed as a set.
If the dust seal is finished, the brake seal will be affected
Old 27-04-11, 09:49 PM   #6
hannakournikova
I have no issues with pattern parts but can't justify buying a full set just for the dust seals
Old 27-04-11, 09:50 PM   #7
hannakournikova
Brake seal is fine. No wear on them at all. Luckily the dust seals done their job fantastically
Old 28-04-11, 06:05 AM   #8
Spanner Man
Good morning all.
Do the job properly & renew the lot. It's only about £18 inc VAT per caliper for genuine seals.
It amazes me that people even consider re using caliper seals, after boiling them in water, & other such practises.
If your bike doesn't start in the morning, it's a pain in the Ar$e, if it doesn't stop, it can hurt all over. Don't feck about with brakes.
Cheers.
Spanner Man
Old 28-04-11, 08:01 AM   #9
hannakournikova
whats wrong with reusing a perfectly good caliper seal?
Old 28-04-11, 08:16 AM   #10
Spanner Man
If the dust seals have had it, there will be some deterioration of the hydraulic seals, even if it isn't obvious. Also, disturbing it won't do it any good either.
Any seal or gasket is only meant to be used once. People often re use fork seals, or gaskets etc. Only to have to do the job again sooner rather than later, due to leakage of some sort.
As I said, why feck around with brakes, for the sake of about £36!
Cheers.
Spanner Man
Dust AND piston seals? Alpinestarhero SV Talk, Tuning & Tweaking 17 27-01-09 08:06 AM
Front calipers: no dust seals tubbycyclist Bikes - Talk & Issues 14 02-01-09 03:14 PM
Brakes - Dust seals removed. Grinch SV Talk, Tuning & Tweaking 7 19-02-07 04:20 PM
Dust Seals TSM Bikes - Talk & Issues 5 01-09-06 10:10 AM
Brake Dust Seals leegriffiths128 SV Talk, Tuning & Tweaking 2 16-12-05 06:59 PM
