Old 14-05-11, 10:18 AM   #1
muzikill
muzikill's Avatar
Default Paint for the silver sub-frame rust repair?
After a search i found a few threads about the rear exhaust footpeg hanger brackets going rusty & the subframe itself. Did anyone in here suss out what they needed to do & what paint to use to repair this?
Here's some pics, have a look at your own in these areas!
Thats what rear huggerless sv's look like!
Old 14-05-11, 11:14 AM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Paint for the silver sub-frame rust repair?
I had a similar thing on the rear subframe of my curvy.
I took it off, had it sand blasted and powder coated, not expensive to really just a bit time consuming stripping the back end down and then sending off for coating and then putting it all back together again.
2011 Speed Triple 1050
Old 14-05-11, 12:34 PM   #3
Powder coating is the way forward.
I think is about £40 ish to have done
Old 14-05-11, 05:35 PM   #4
chirpy999
Try spray Hammerite if you are on a budget , about £10 a tin.
chirpy999 is offline   Reply With Quote
Old 14-05-11, 05:59 PM   #5
Not hammerite, use silver smoothrite, its fairly close to the OEM.
But I agree with the others get it powdercoated
Swingarm, sidestand & footrest hangers in chrome silver powder coat
Old 14-05-11, 10:19 PM   #6
Lozzo
If you're keeping it then powder coat it, if you're tidying up to sell then silver Smoothrite is a very good match and lasts well if you apply it properly
Rust on k3 frame cringer Bikes - Talk & Issues 3 23-09-10 10:00 AM
Silver Frame Paint Code? DF! SV Talk, Tuning & Tweaking 6 14-09-08 08:07 AM
SK3 R&G Crash Protectors: Frame Bolt Rust? Tallguy SV Talk, Tuning & Tweaking 12 09-09-08 07:58 PM
Frame Paint wheelnut SV Talk, Tuning & Tweaking 1 08-09-07 12:13 AM
sub frame rust! socommk23 SV Talk, Tuning & Tweaking 9 19-04-06 04:28 PM
