Old 14-05-11, 12:55 PM   #1
daveyrach
Default Stebel Magnum fitting questions.
Right finally had my Stebel Magnum horn delivered this morning and have a few Q's
1. Where do i mount it, is it ok to mount on the standard OEM horn bracket?
2. Does it have to be wired separately or can it just be plugged into the OEM plug (Don't wanna blow the loom)
3. Does it have to have a new relay wired in?
4. What harm can be done if it is plugged directly into the OEM loom.
Pack says it draw 5.5 amps @12v is this safe for plug and play?
Old 14-05-11, 08:23 PM   #2
daveyrach
Default Re: Stebel Magnum fitting questions.
Anyone??
Old 14-05-11, 08:28 PM   #3
SoulKiss
SoulKiss's Avatar
Originally Posted by daveyrach View Post
Anyone??
I just swapped the stock for a magnum on my pointy and its not been a problem.
Didnt answer earlier as you have a curvy
Old 14-05-11, 09:33 PM   #4
HoL
Let me know how you get on, I was going to fit one too - it all seems a trifle confusing with all the previous talk of installing relays etc. A swap over sounds way easier
Old 14-05-11, 09:38 PM   #5
daveyrach
I am perfectly capable of wiring a relay in and have no probs in doing it and how it all works, just wondered if it is necessary
Old 14-05-11, 09:43 PM   #6
Does it say on the standard horn what current it uses?
Old 14-05-11, 09:56 PM   #7
Nobbylad
Nobbylad's Avatar
Try using the search function, there's a full thread on it and some schematics.
Old 16-05-11, 08:57 AM   #8
daveyrach
I know the why's a how to do it just wonder if it was completely necessary if it only draws 5.5amps, does anyone know whhat the curvy horn wiring can carry amperage wise?
Old 16-05-11, 09:53 AM   #9
warmshed
The curvy circuit is fused at 15 amps and the wiring is quite capable of carrying the 5 amps you will draw, the only reason to use a relay in this situation is to reduce volt drop which will affect the loudness of the horn, or to protect the switch from over loading, leading to a fault. As the existing horn takes a similar current the switch will be fine. You will need to lengthen the wire about 2-3 inches to make sure you can route it without it being tight. I used the original bracket that is shorter than the one with the horn. Horn works fine.
Old 16-05-11, 10:31 AM   #10
daveyrach
So you didn't use a relay? I just don't want to melt anything
I was having a look last night i think i will also use the OEM bracket as it seems to look neater.
For Sale-Stebel Magnum- fecking loud :-) SOLD stewie For Sale - Other Bikes and General biking items 7 03-06-09 07:34 AM
Stebel Magnum Horn Stradders SV Talk, Tuning & Tweaking 5 20-10-08 07:49 AM
stebel magnum ? hovis SV Talk, Tuning & Tweaking 37 22-06-07 09:46 AM
Stebel Magnum horn - fitting Tigerrrr....... SV Talk, Tuning & Tweaking 3 23-09-06 09:45 PM
Stebel Magnum horn bendelfont SV Talk, Tuning & Tweaking 5 11-07-05 09:08 PM
