Old 19-05-11, 08:18 AM   #1
schmector
Default error code c24
Hi im new to this fourm but I have been using this one and svrider.com for some info but i am having an error code c24 i know it is for my front ignition coil but i have checked everything i can i get 3.8 ohms on my coils and 29k ohms on my spark plug cap i get the same reading from both cyclinders but can only run on my rear i have changed my spark plugs and i am so far lost now...i posted a thread on svrider but have had no luck so im hoping that i can hopfully get some suggestions on this site i ride a 04 sv650s changed to naked after the crash it had from the previous owner
ANY help would be so greatful
~Sanders
Old 19-05-11, 03:03 PM   #2
schmector
Default Re: error code c24
?? anyone please
Old 19-05-11, 10:12 PM   #3
The error code is generated at the ECU, this means that the ECU sees a problem with the coil but that it sees that from the end of the bit of wire that connects the ECU to the coil.
That's what I'd check first - the wiring.
Old 24-05-11, 01:16 AM   #4
schmector
i checked all the wiring with a volt meter and it seems to be my ecu is fried but thank you =)
error code c-42 pencil shavings SV Talk, Tuning & Tweaking 66 24-05-21 01:57 PM
Bike wont start. (ignition doesn't throw an error code) stamford Bikes - Talk & Issues 6 03-08-09 12:49 AM
FI error code c44? Bibio SV Talk, Tuning & Tweaking 0 29-05-09 02:13 PM
Startup Error - What does it mean? Doofer SV Talk, Tuning & Tweaking 11 26-03-09 09:59 AM
