Old 20-05-11, 09:04 PM   #1
hhh1234
Default problems after changing voltage regulator
well folks i changed my 99 vr to a 600 cbr vr last month as mine was playing up, i went on a 600 mile trip to scotland last week and as i got off the boat thankfully after id finished the trip, i gunned it for home the bike did a massive backfire and stuttered for a second i thought nothing much of it and carried on home, rest of the way home the bike kept spluttering , backfiring and stalling when i seemed to give id acceleration it tended to worsen the problem. when i took seat of to have a look my 3 way connector from vr to fuse box had exploded. bought new one changed it went for a spin today 5 miles into trip it did it again, splutter backfire and stall. can anyone help me out
jonny
ps sorry for the story
Old 20-05-11, 11:52 PM   #2
TamSV
TamSV's Avatar
Default Re: problems after changing voltage regulator
Just a thought, but have you checked the AC voltage coming from the generator?
Old 21-05-11, 06:41 AM   #3
hhh1234
13.5 v when ignition on and 14.5 on idle
Old 21-05-11, 11:27 AM   #4
jambo
jambo's Avatar
That's not the AC voltage. Tam is asking about the voltage between each of the 3 pins from the generator before it goes into the reg/rec.
Jambo
Edit: Sorry that's come across a little abrupt. The reg/rec takes ~80v AC and converts it to ~13.5v DC. Before knowing if it does it's job, it's worth checking it's getting the correct amount of power to step-down in the first place
Old 22-05-11, 07:50 AM   #5
hhh1234
Ok cheers will check later
Old 24-05-11, 01:34 PM   #6
hhh1234
right checked each of them and reading are 10.5 - 11.2
Old 24-05-11, 08:00 PM   #7
jambo
jambo's Avatar
If your generator is genuinely outputting 10v AC, then there isn't enough power to convert into the 13v DC needed to charge the battery / power the bikes electrics. This would mean there was likely a problem with the generator coils or magnets.
However, as that's the sort of number you might get if measured incorrectly:
I am assuming:
1) You've voltage meter that is is set to AC Voltage (not DC).
2) You have unplugged the 3 connectors from the generator to the reg/rec and with the engine running you're measuring AC voltage between each of the 3 connections.
Jambo
Old 24-05-11, 09:03 PM   #8
TamSV
TamSV's Avatar
Set your multimeter to AC. It's shown as V~ I think. Set it to 100V~ and make sure the leads are connected in the correct sockets as per your meters instructions.
Disconnect the Reg/Rec connector with the three yellow wires and do the test on the bike side of the connector, not the reg/rec side.
You want to take three readings across the pins in pairs. So if you number the pins 1 to 3, take a reading across each of 1 & 2, 1 & 3 and 2 & 3.
Take readings with the engine running at tickover and again at around 5000rpm.
Old 04-06-11, 12:09 PM   #9
hhh1234
ok ive done that with the bike running
1&2 = 23
1&3 = 23
2&3 = 23
Old 04-06-11, 12:12 PM   #10
hhh1234
with bike reving at 5k
1&2 = 82
1&3 = 83
2&3 = 83
Gear changing problems vardypeeps SV Talk, Tuning & Tweaking 2 02-04-09 01:05 PM
Broken voltage Regulator MavUK SV Talk, Tuning & Tweaking 7 05-03-09 01:13 PM
Problems Changing Gear with Oxtar TCS TheShadow Bikes - Talk & Issues 12 22-07-08 07:51 AM
Voltage regulator / rectifier Alpinestarhero SV Talk, Tuning & Tweaking 6 16-08-07 03:53 PM
