I am in need to fire proof an attic which is in an old cottage. For a mortgage it must be fire proof due to a fire could spread in the attic space to next door. what material is best to use? i have heard that Fireline boards are good and probably the cheapest option. do they then have to be fitted to a wall or just a frame?
any help is appreciated. |
I used chicken wire stretched across and into the joists, stapled onto the sides so it basically went over each joist, down the side across the space between joists, up the side of the next, over that one and repeated all the way across. Then the space between the joists was filled with rolls of fireproof Rockwool. The reason for the chicken wire was to prevent the Rockwool falling down in the event that a fire burns through the plasterboard ceiling below.
Best thing to do is to check latest building regs/ask the building control department of the local council. |
when I did mine in 2007 I used 2 layers of plaster board, on all rooms excluding the bathroom. The door to the loft is a fire door and the area around is is twin skin also, it was passed by Building Control.
A good place to start would be your local Building Control office. |
#4 | |
The green rockwool slabs are fire retardant and not expensive, Ideally, you could replace the plasterboard on your ceilings with pink fire board but this is expensive to do. 8x4 sheet of pink fire board is approx £10 a sheet and then it will need plastering. Last edited by Specialone; 21-05-11 at 05:48 PM. |
Thanks for the quick posts. I will check with the local authorities. I only need to fire proof so that a fire could not spread through the attic space from nexr door. Not so much to replace the ceilings. Any more info would be great.
Rob |
yes.. all the above or you can look into fire curtain. I have shed loads I can sell you if you like for cheap, the architect changed the spec last minute after we had ordered...
Also look into intumiscent spraying.
You can treat timber for fire protection and fire foam will fill gaps in timber framing and brickwork. Is it a large void in the roof or just an incomplete wall? If its a void, you will have to build a partition and plasterboard it (30min FP) but if theres only small gaps, foam will be the easiest, cheapest and quickest way of doing it. |
Water proofing leather gloves | Nick_69 | Bikes - Talk & Issues | 8 | 04-08-10 11:06 PM |
Fire in the sky. | rictus01 | Photos | 10 | 12-10-09 11:09 AM |
Winter proofing my bike. | Brettus | Bikes - Talk & Issues | 10 | 14-09-09 08:46 PM |
Noises In My Attic | Speedy Claire | Idle Banter | 66 | 18-06-09 01:40 PM |
Fire & Ice | Kinvig | Idle Banter | 4 | 09-11-07 03:37 PM |
