Old 27-05-11, 07:23 AM   #1
christian1000
Default Fuel Pump Compatibility?
Hi All,
A friend of mine (who isnt on this forum) is on the look out for a replacement fuel pump for a K4 SV650S having been quoted a silly price for a new one.
Does anybody know as to the interchangability of K3/K4 pumps with K5+. I seem to remember there being a change at some point to add a double level reserve indication?
Or as per usual I could be completly wrong.
Any advice would be much appriciated
Christian
Old 27-05-11, 09:05 AM   #2
muzikill
muzikill's Avatar
Default Re: Fuel Pump Compatibility
http://www.svspares.com/catalogue/22...nd-exhaust.htm
Up to k3 it uses a white plug to power it, beyond that a brown plug. Give them a ring first to check and order just to make sure.
Old 27-05-11, 08:07 PM   #3
christian1000
Righto cheers gonna get him to check the type of connector it's got
Old 31-05-11, 02:52 PM   #4
christian1000
Default Re: Fuel Pump Compatibility?
Sorted thanks, he's ordered one from SV spares, needed a White plugged one for his K4 it would seem.
Fuel Pump. K6 SV650 Noble Ox For Sale - SV's and SV related items 1 03-04-11 04:38 PM
SV fuel tank compatibility? Teejayexc SV Talk, Tuning & Tweaking 2 28-10-10 05:58 AM
Fuel Pump Problem hindle8907 Bikes - Talk & Issues 2 29-11-09 01:34 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
