Okay, some of you may have seen my other thread where my bike keeps being blowing over in the wind: http://forums.sv650.org/showthread.php?t=166806
Long story short the front cylinder filled with oil and i tried to start it. The bike now runs, but not on the front cylinder. I've got spark, i've tried changing the plugs round too. There is visable pressure in the front cylinder as it will move a rag stuffed down the plug hole, carbs seen to be fuelling too. I'm kinda down about the whole thing but before i decide to scrap the bike i would appreciate any tips or advice on what to do next. Compression test? or are there any other simple checks or procedures which would help me identify what's wrong? Last edited by farquare; 29-05-11 at 08:04 PM. |
Doesn't sound good I'm afraid, as you might have bent a rod if it was hydraulically locked?
Can you turn the engine over with the back wheel on the paddock stand when its in gear? Front plug clean & working?
We're riding out tonight to case the promised land Make everyday count RIP Reeder - Jolly Green Giant and comedy genius Last edited by maviczap; 29-05-11 at 08:54 PM. |
Hi,
To be fair its prob bent the conrod ive seen this a few times on vehicles i have worked on (mainly Buses and trucks) but wouldnt like to say this is the cause for it not running on that cylinder can you measure the height of the piston with the plug out and do the same on the good side? Ive never really hand much to do with motorcyle engines but have rebuilt a fair few heavy goods. Sorry not much help Gaz |
I'm with mavi, sounds terminal (if everything else is tickety boo). You wouldn't be able to check for a bent crank without stripping the motor.
pm yorkie chris or rictus mate
i can understand bending a crank if the engine was running when fluid gets in, the bang in the good cylinder having massive opposite force on the other.
but would trying to start a bike with 1 clyinder full of oil have enough power to do damage? the starter did not spin just engaged and stopped due to the resistance.... |
#7 | |
Engine oil would theoretically combust under very high pressure/ compression
i've pretty much resigned myself to the worst by now, looks like no biking for me this year.
thanks for the replies and suggestions. |
#9 | |
Simple physics you can compress a gas, but not a liquid. Hydraulic lock in a diesel is a bad thing, and not much better in a petrol.
#10 | |
Bent rod is slightly better than a crank.
Engine oil change - 5 months no engine starting | sv650sfan | SV Talk, Tuning & Tweaking | 2 | 04-03-11 08:10 AM |
Engine cleaning b4 engine strip w.i.p | muzikill | Photos | 2 | 16-01-11 06:20 PM |
engine bolts for point engine | pookie | Stuff Wanted | 6 | 01-10-10 01:50 PM |
Engine Breaking? Hopefully not. Engine braking - is that OK? | butterick99 | SV Talk, Tuning & Tweaking | 14 | 12-09-09 10:31 PM |
Engine braking... any hazzards engine wise? | John 675 | SV Talk, Tuning & Tweaking | 21 | 28-03-08 07:20 PM |
