Old 31-05-11, 07:44 PM   #1
hannakournikova
Default Butchered Wiring for indys :(
Guys, trying to wire up the indicators but they appear to have been attacked.
Anyone help?
Old 31-05-11, 07:50 PM   #2
warmshed
Default Re: Butchered Wiring for indys :(
Get a soldering iron and some heat shrink tube, If you want a plug and socket get the correct one and solder the connectors rather than crimp. Wont take much to make it neat and more importantly, not a potential hazzard.
Old 31-05-11, 08:02 PM   #3
Winder
Winder's Avatar
Agreed. Just get rid of all the connectors and crimps with a simple snip. Extend cables to the required length, use the stock indicator connectors.
Solder and heat shrink is better and neater than crimp or twist and go with tape on
Old 31-05-11, 08:06 PM   #4
Butcherd is an understatement
Old 31-05-11, 08:33 PM   #5
Noddy
Looks like Stevie Wonder could have done a better job. I assume the previous owner had shares in chocolate blocks and crimps. As previously stated extend the wires and solder and shrink. Will cost pennies and look 100% better than existing, should also do away with any potential reliability issues.
Old 31-05-11, 08:36 PM   #6
hannakournikova
Sorry guys should have stated that I'm after a colour reference or wiring diagram. Need to wire them in and a number plate light.
On the plus side it will weight about 3kg lighter lol
Old 31-05-11, 08:48 PM   #7
warmshed
I can copy the relevant part of the wiring diagram, What bike is it? Year would be nice.
Old 31-05-11, 09:03 PM   #8
hannakournikova
It's 2000 chum
Old 31-05-11, 10:34 PM   #9
warmshed
PM sent to you to send you a wiring diagram.
Old 01-06-11, 07:20 AM   #10
daveyrach
Mine's like that i just simply put the male spade connectors on the number plate wiring and plugged it in, i do have an aftermarket LED number plate light tho, saying that all the indicator connectors have been cut off and replaced with spades. Likei say just a case of cutting the connector off whatever you want to plug in and putting male connectors on, no biggie really.
no indys sv650nutter149 Bikes - Talk & Issues 3 31-08-09 11:38 AM
Shiny Can Butchered in Workshop Frenzy..... independentphoto Photos 3 15-08-08 12:20 AM
LED indys. Rich Bikes - Talk & Issues 10 29-05-08 10:58 PM
LED Indys ukhammy SV Talk, Tuning & Tweaking 1 30-12-07 05:14 PM
wiring resistors into your indys?(elec help needed) kwak zzr SV Talk, Tuning & Tweaking 39 16-03-07 09:23 PM
