Old 01-06-11, 09:33 PM   #1
Default Refurbishing electrical contacts
As per the title, I'm wanting to refurbish the electrical contact on my old switch gear from the bike.
The ones in need of work are the 'pass switch' and horn (the large plate contacts) but I'm doing the whole lot while its in bits.
Whats the best way to go about it
Thanks in advance
Andy
Old 02-06-11, 08:10 AM   #2
Default Re: Refurbishing electrical contacts
WD40/the squirty spray that you already have in your toolbox, and a light scrub with a wire brush, preferably brass.
For a final polish use some firm paper - it's quite abrasive and will leave a nice smooth polished finish.
Don't forget to squirt whatever spray you have into the holes in the switchgear every now and again - then you won't need to take it apart to clean it again.
Old 02-06-11, 08:37 AM   #3
tigersaw
tigersaw's Avatar
Agreed. Electrical contacts can be cleaned by pulling a business card between them - I used to moonlight fixing pinball machines and they are full of contacts. Never use anything too abrasive like sandpaper or a file, it will destroy the contact surface and it will fail again very quickly.
Old 02-06-11, 08:42 AM   #4
cheers lads.
Would a steel emery board be alright for the final finish?
Old 02-06-11, 08:44 AM   #5
http://cgi.ebay.co.uk/Servisol-Super...QQcmdZViewItem
Old 02-06-11, 09:13 AM   #6
tigersaw
tigersaw's Avatar
cheers lads.
Not really. Switch contacts are soft, you need to clean them with something softer
Art contacts Shellywoozle Idle Banter 15 22-03-10 10:51 AM
Wheel Refurbishing Mike2165 Bikes - Talk & Issues 3 02-04-09 05:31 PM
ICE Contacts Kinvig Idle Banter 12 17-07-06 12:59 PM
Contacts belfastbiker2003 TOTALSV Ireland 1 03-08-05 06:01 PM
