Old 08-06-11, 01:14 PM   #1
Default Seat panel bolt - Pointy
Other than a main dealer, where can I get a new bolt for the black plastic diamond covers under the seat? The head on mine is knackered. It's just an M6 bolt but it has a large shoulder with no threads.
Thanks
Old 08-06-11, 02:41 PM   #2
Nobbylad
Nobbylad's Avatar
Default Re: Seat panel bolt - Pointy
Difficult to find an exact match, however I think I have some generic M6 allen head bolts knocking around and could send you one. I think the shouldered bit on the stock item is there to prevent you tightening the bolt up so tight as to crack the panel.
If you find some the same as the stock ones, let me know.
Old 08-06-11, 03:15 PM   #3
Yeh I've got loads of M6 ones, just wanted to get the proper thing if possible. If not I'll probably just see how much suzuki want
Old 08-06-11, 03:41 PM   #4
TamSV
TamSV's Avatar
I've got a spare from the curvy you can have.
There's a good chance they're the same but worth double checking before I post it. Do you want to measure the shoulder/thread lengths and I'll do similar?
Old 08-06-11, 03:59 PM   #5
Nobbylad
Nobbylad's Avatar
Would be good to find somewhere (online) that sells 'em.
As well as the 'top hat' style spacers that are used as inserts on the fairing mounting bolts.
Old 08-06-11, 04:04 PM   #6
That would be great. I'll get measurements either when I get home tonight or tomorrow
Old 08-06-11, 04:11 PM   #7
DavieSV
DavieSV's Avatar
http://www.shoulder-screws.co.uk/?gc...FcRtfAod3yYJxA
Closest I can find
DavieSV is offline   Reply With Quote
Old 08-06-11, 04:41 PM   #8
Nobbylad
Nobbylad's Avatar
http://www.avonstainlessfasteners.co...20.htm#ISO7379
Old 08-06-11, 04:44 PM   #9
i got some SS tube of ebay that fits the holes perfect. i just cut it down when i'm needing a spacer for a bolt. bit of a cuffuffle but it make the spacers penny's.
http://cgi.ebay.co.uk/NEW-STAINLESS-STEEL-ROUND-TUBE-8mm-x-1mm-x-250mm-316-/150603683706?pt=UK_BOI_Metalworking_Milling_Weldin g_Metalworking_Supplies_ET&hash=item2310add77a
Old 08-06-11, 04:50 PM   #10
burger i made a mistake and its directing to 10mmx1.5. it should be 8mmx1
Side panel bolt size query? Dfraser76 SV Talk, Tuning & Tweaking 8 06-02-15 06:57 PM
Left hand seat panel K4 Pointy wanted arcoiris Stuff Wanted 4 31-05-11 03:40 PM
Pointy indicators, lower fairing panel / cockpit trim panel, F Brake resevoir. dubno Stuff Wanted 4 22-07-09 10:23 AM
L/H Seat panel in silver 03- Stewart.C Stuff Wanted 0 05-05-09 08:16 AM
SV650 K3 seat panel belgarion SV Talk, Tuning & Tweaking 0 10-09-07 07:44 AM
