Old 23-06-11, 01:49 PM   #1
hindle8907
hindle8907's Avatar
Default Finding neutral when cold.
Latley im finding it really hard / impossible to put the bike into neutral when the engine is cold.
Can Anyone shed any light.
its a 2000 curvy with around 35000 on the clock. recently had oil change too.
Cheers Ant,
Old 23-06-11, 02:10 PM   #2
TamSV
TamSV's Avatar
Default Re: Finding neutral when cold.
Double check the oil level.
Check the chain tension.
Also worth checking the clutch adjustment - see Sid Squid's many posts on the subject.
EDIT: I just noticed you said it happens when the bike's cold. Makes me suspect the clutch adjustment even more - a dragging clutch tends to ease off as the oil warms up. Check the other two as well, for all the time it takes.
Old 23-06-11, 03:53 PM   #3
_Stretchie_
Large Member
_Stretchie_'s Avatar
You having trouble finding the little one in the middle when it's cold
How to amuze an idiot:
Look right-> <-Look Left
Old 24-06-11, 09:56 AM   #4
johnnyrod
johnnyrod's Avatar
Mine's fine 99% of the time unless the clutch adjuster has rattled in too far. For me, oil level doesn't affect it but yes chain tension does, dunno why, but tighter is betetr it seems.
Old 24-06-11, 10:01 AM   #5
hindle8907
hindle8907's Avatar
Cheers guys had a play with the clutch adjustment and seems better. will do it at both ends over the weekend.
Old 25-06-11, 09:27 AM   #6
metalangel
Finding my old SV - how? Rick K SV Talk, Tuning & Tweaking 7 29-08-10 09:35 PM
Trouble finding neutral. Stuuk1 SV Talk, Tuning & Tweaking 15 30-09-09 03:45 PM
Help finding a BBC documentary lukemillar Idle Banter 2 12-09-08 09:24 AM
finding a job after uni riktherider Idle Banter 6 07-07-08 08:32 PM
Finding Neutral DanDare SV Talk, Tuning & Tweaking 11 17-05-05 11:38 AM
