Old 27-06-11, 09:19 AM   #1
600+
Default Stebel Nautilus issue
Anyone can help?
Horn was working fine till Germany trip. CAme back washed the bike and put it in the garage. Not used it for about a month and took it out yesterday to find the horn was not sounding loud enough and also sounds a bit "rough"?
Checked connectors they are fine with no corrosion etc.
It has got a bit better after using it a bit.
Any ideas?
Old 27-06-11, 10:06 AM   #2
Luckypants
Luckypants's Avatar
Default Re: Stebel Nautilus issue
I suspect a bit of corrosion on the diaphragm, either caused by road crap getting in or by over enthusiastic washing getting water in there. The fact it's got better with use backs this up. Use it more and it may clear completely.
If it is water / crud getting in, make sure the trumpet is either shielded or facing down to minimise the chances of it happening again.
Old 27-06-11, 10:48 AM   #3
600+
Ah cheers Mike. It's fitted horizontally so I'll check if it is facing fwd and move it around.
Would some WD40 help if it is corrosion on the diaphragm?
How do you split a stebel Nautilus ? SIII Bikes - Talk & Issues 20 23-03-11 08:22 PM
Stebel Nautilus - maintenance help Nobbylad SV Talk, Tuning & Tweaking 2 26-03-10 03:42 PM
Stebel Nautilus Horn appollo1 For Sale - Other Bikes and General biking items 2 20-10-09 07:52 PM
Stebel Compact Nautilus ibshort Stuff Wanted 1 21-05-09 01:10 PM
Stebel Nautilus Horn philthunder Ancillaries 2 06-03-05 09:57 AM
