Old 30-06-11, 08:29 AM   #1
Galviniser
Default Drill through axle?
Howdy,
I was just wondering that, because my front axel isn't hollow, can I drill a 5mm hole through about 20mm deep? I have an axel nut cover but required a hollow axel, so if I do this then tap the hole I can then screw the nut cover just in my axel and can be removed if needed. I will post some pictures when finished
Chris
Sent from my HTC Desire using Tapatalk
Drill bits BBadger Idle Banter 20 18-06-10 02:33 PM
Scrounging a drill Stu Guildford Massive 10 10-04-10 06:46 PM
Corded Drill Ch00 Idle Banter 19 29-06-09 06:37 PM
Power drill rubberduckofdeath Idle Banter 14 04-03-08 09:58 PM
drill advice hovis Idle Banter 33 12-02-07 12:08 PM
