Old 02-07-11, 04:01 PM   #1
barwel1992
Default air compresser for air tools advice needed
im looking to get a compresser to run an impact gun and stuf like that
but im not that up to speed on them i have been looking at a v twin 3hp comp with 50l tank with 15cmf and and 6 bar for £170
do you think that would be adequet
also any good sites to get air lines allready made up with quick relese fittings
basically any advice would be good
PS sorry for spelling no spell check on this pc
ta
Old 02-07-11, 04:04 PM   #2
flymo
flymo's Avatar
Default Re: air compresser for air tools advice needed
check the tools themselves, they normally provide the air consumption figures. Also take into account how long they will be operated for, a larger tank will let you run the tool for longer without waiting for the compressor to fill it every five minutes.
Old 02-07-11, 04:13 PM   #3
barwel1992
not to bothered about waiting for the tank to fill as its not going to get used loads just to losen bolts on the car
ok the gun i want specs at
4cfm
90psi
270lb ft
or
5.6cfm
90psi
450lb ft
ohh and these are the actuall spec of the compressor
230v Single Phase Compressor
50 Litre capacity receiver
MWP 116psi 8 Bar
14cfm
Old 02-07-11, 07:44 PM   #4
Electro
The compressor will be fine mate, it will run 3 x the 1st tool without a prob.
Old 02-07-11, 07:47 PM   #5
barwel1992
cool, will probs get the second gun for removing drive shaft nuts
Old 03-07-11, 04:19 PM   #6
timwilky
timwilky's Avatar
Check your fittings can deliver the flow rate. I ended up having to fit a 1/2" fitting and bigger pipe to drive my impact guns.
Not Grumpy, opinionated.
Replacing Clutch - which tools needed? bengodden SV Talk, Tuning & Tweaking 1 01-02-11 12:56 PM
Engine split advice - what special tools? muzikill Stuff Wanted 2 11-07-10 09:07 PM
It's about time I bought some tools. Socket set, Torque Wrench & some other bits. ADVICE plz... Paul the 6th SV Talk, Tuning & Tweaking 21 24-01-08 07:36 AM
any special tools needed for clutch investigation work? grecian9 SV Talk, Tuning & Tweaking 3 22-09-06 03:04 PM
Need tools - advice please! jenni SV Talk, Tuning & Tweaking 28 24-08-05 06:59 PM
