Old 05-07-11, 03:53 PM   #1
BBadger
Default Removing polish?
Ive started to try and polish out some of the scratches on some plastics, using new mops and very fine grade polish, only a small amount on the mop each time, never staying in the same place for to long and constant flowing movement.
Now my problem is its leaving a the waxy residue behind in small and large amounts that is almost impossible to get off without hours of scrubbing.
ive tried white spirit, teacut, brake cleaner, brick cleaner, nitromorse and heat but nothing seems to shift it at all.
ideas people ? or should i just crack out the marigolds and scrub away?
Thanks
Brock.
Old 05-07-11, 05:15 PM   #2
jambo
jambo's Avatar
Default Re: Removing polish
Ride
The
Bike
Love Jambo x
Old 05-07-11, 05:48 PM   #3
BBadger
its got to look pretty before it goes outside in the big world.
also massive lumps and lines of hard polish is not a good look.
Old 05-07-11, 06:59 PM   #4
speed to fast on the mop?
try Farecla G3 liquid
http://www.youtube.com/watch?v=2A56acHlFQ8
Old 05-07-11, 07:01 PM   #5
Teejayexc
Can't you just put 'em on airplane or the ferry ?
< Oops, grabs coat and makes for the door >
Old 05-07-11, 07:06 PM   #6
ty_uk
http://www.amazon.co.uk/XERAPOL-PLAS...ref=pd_cp_ce_2
Old 05-07-11, 07:28 PM   #7
BBadger
Been waiting for that one!
Do you think these will remove the resin thats left over that nothing else seems to shift ??
and maybe to high a speed but i was under the impression that to slow and id get this effect.
Old 06-07-11, 01:30 AM   #8
i take it you are referring to polishing clear and or unpainted plastics? if so then you are best hand buffing. the build up of 'waxy residue' might not be polish it might actually be the plastic itself. try using some water to cool the buffing head and don't press to hard, let the buffer do the work.
Old 06-07-11, 09:23 AM   #9
BBadger
Default Re: Removing polish?
ill give it a go with another mop and plenty of water and get back to you on it later with results
thanks guys
Best Wax / Polish? sauluk Bikes - Talk & Issues 24 23-03-10 11:26 PM
Will this polish out? -Ralph- Bikes - Talk & Issues 13 27-12-08 08:12 PM
Bit of a polish! pencil shavings SV Talk, Tuning & Tweaking 22 31-05-08 07:23 PM
paint and polish busasean SV Talk, Tuning & Tweaking 2 06-11-06 05:25 PM
How do you Polish yours? fraser01 Bikes - Talk & Issues 19 24-10-04 07:49 PM
