Old 09-07-11, 08:37 PM   #1
muzikill
muzikill's Avatar
Default Lower fork triple clamp painting
Tools used. i used an old can top and sprayed some paint into it for dipping a fine artists brush in to paint from.
before...
Took my time making sure i got it painted everywhere.
After...
Doddle to do as im changing the fork oil. The paint is a perfect match as everyone says.
Group Buy - SVN-GSXR Custom Triple Clamp gjscott For Sale - SV's and SV related items 47 15-03-17 09:11 AM
Top yolk/triple clamp needed asap daveyrach Stuff Wanted 2 25-04-11 08:03 PM
02 sv650s triple clamp question eamonnconnor SV Talk, Tuning & Tweaking 0 23-04-07 08:20 PM
nakedfying a sporty lower triple clamp Torn-Thorax SV Talk, Tuning & Tweaking 5 01-04-07 02:24 PM
Lower triple clamp Torn-Thorax SV Talk, Tuning & Tweaking 3 16-09-06 05:59 AM
