Old 19-07-11, 09:56 AM   #1
dave_c24
Angry Help, cant undofront sprocket
Hi guys
Trying to do the simple task of changing the chain and sprockets on the sv. Ive knocked bak the tab, put the bike in gear, and got a mate holdin on the brake. Even with a 3ft bar on it it wont budge!!! Im turning the back wheel with the brake on!!
Ive tried different gears and also claping the chain with a pin through it so it couldnt move and ive bent the pin i was using. Im trying to turn the nut anticlockwise to undo, im 99.9% sure its not a lefty
Any ideas would be much appreciated
Old 19-07-11, 10:00 AM   #2
stormingjoe
stormingjoe's Avatar
Default Re: Help, cant undofront sprocket
If you have a jack handle or other suitable bar long enough, put it through the wheel above swing arm, turn wheel till the spoke rests on the handle then undo the nut, put under swingarm when re-tightening nut.
stormingjoe is offline   Reply With Quote
Old 19-07-11, 10:26 AM   #3
Luckypants
Luckypants's Avatar
As above but use a bit of wood, its less likely to mark the swing arm. Wrap the swing arm or bar/wood in rags to further cushion it if you want no marks.
Old 19-07-11, 10:29 AM   #4
timwilky
timwilky's Avatar
+1, what he said about wrapping it to form a cushion, although I use a small length of scaffold tube
Not Grumpy, opinionated.
Old 19-07-11, 10:43 AM   #5
NTECUK
NTECUK's Avatar
Electric impact gun. They do one for about£80 at machine mart.
Really handy bit of Kit.
Old 19-07-11, 10:44 AM   #6
TamSV
TamSV's Avatar
And just to confirm, you're right, it's a regular thread - anti-clockwise to remove.
Old 19-07-11, 01:15 PM   #7
_Stretchie_
Large Member
_Stretchie_'s Avatar
If you haven't got an inpact gun (electric or air), try an impact driver about £10 from Halfords, or try and heat the nut, I have a butane blow lamp from some B&Q type place for about £15-£20
Like this one
http://www.google.co.uk/products/cat...ed=0CGUQ8wIwAA#
You don't have to get it glowing or anything, just get it heated up and hopefully that will free it up
How to amuze an idiot:
Look right-> <-Look Left
Old 19-07-11, 01:57 PM   #8
dave_c24
Cheers for all the tips guys, tried the bit of wood (2x1) wedged in wheel and snapped it before it moved! So used a bit of ally bar and ended up using a scafold pole (6ft) to get it to move. Never have a seen one that tight, it was a struggle with the pole on it.
Done now and shiney sprockets and gold chsin fitted
Old 21-07-11, 11:29 AM   #9
I've had to grind one off before when the wheel crunched a 3x2 even with my ginger mate stood on the brake!
Old 21-07-11, 01:00 PM   #10
mikerj
There is an oil seal right behind the sprocket, not a good idea to get any heat in this area.
520 Sprocket Christian525 Stuff Wanted 1 14-09-10 03:22 PM
Getting a different sprocket - where from? dazzaboy SV Talk, Tuning & Tweaking 1 05-08-10 07:41 AM
sprocket sv_rory SV Talk, Tuning & Tweaking 3 12-02-09 12:54 PM
14 T sprocket Quiff Wichard For Sale - SV's and SV related items 9 14-08-07 12:10 PM
Sprocket !! skulpt SV Talk, Tuning & Tweaking 5 11-10-06 07:26 AM
