Already found a topic on here and I've tried applying heat and I've used a full tin of WD40 and nearly broken my arms off using a set of grips to try and get the choke plunger out of the front carb but it just won't budge... any ideas?
Are you talking about the screw? Or the plunger its self. As the plunger should pretty much full out when u have undone the screw
Curvy With Lots Of Bits ...
But Still More To Come ![]() |
Yes definitely the plunger, I had to drill the screws off as they were corroded to hell. The rear plunger came out very easily but the front is stuck fast
#4 | |
To the OP - if its that stuck, then your other alternative might be to cut your losses and look for a 2nd hand set of carbs. I would wait a while and see if somebody more knowledgable than me can advise you though.
Got it out! Took the best part of 2 hours, a full can of wd40, a set of grippers a hammer and a flat head screwdriver. It was completely seized and will have to be replaced. Now to clean the whole thing and see if the carbs are the reason for it having no power like it misfiring
Infact where do I get a new plunger from o_O ebay there are none :'(
Try a post in the wanted section here as someone might have one knocking about.Other than that I would say Mr Suzuki?
#8 | |
Look here http://www.robinsonsfoundry.co.uk/co...01999-2002.htm as you get split digrams as well. You can also buy from them they are a suzuki dealer Hope this helps unlike my crapy posts earlyer
#9 |
thanks m8 that looks a good site, just need to look up the part numbers they will be in my haynes right?
#10 |
Part numbers on the robinsons site above. Click on carburetor sub heading and pick from the list under main diagram or click here if it works. No part numbers in my haynes, just say's plunger assembley as a whole.
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
Carb plunger o ring size? | bigchris | SV Talk, Tuning & Tweaking | 12 | 07-07-11 12:43 AM |
Stuck Choke Plunger | 2000curvy | SV Talk, Tuning & Tweaking | 8 | 14-12-10 06:58 PM |
Part number of choke plunger? | ELR4ever | SV Talk, Tuning & Tweaking | 2 | 16-01-08 05:19 PM |
Think i've seized it :-( | Daimo | SV Talk, Tuning & Tweaking | 22 | 22-07-06 06:34 PM |
Rear Carburettor Choke Plunger Screw | fizzwheel | SV Talk, Tuning & Tweaking | 8 | 09-04-06 07:51 PM |
