Old 27-07-11, 06:18 PM   #1
Lucas66
Default Best oil? Yet again.
best oil for a sv1000s?
i put castrol power 1 in my cbr600rr and that seemed to make engine spin up quicker but its fully synthetic will it affect the sv?
Old 27-07-11, 06:25 PM   #2
MJC-DEV
MJC-DEV's Avatar
Default Re: best oil
I always use fully synthetic in the SV.
Use correct quality rating eg, SF, SL etc, oil viscosity (weight) is secondary.
Lots and lots on oil in the org.....
MJC-DEV is offline   Reply With Quote
Old 27-07-11, 06:27 PM   #3
Lucas66
cheers mate its just i know some bikes you have to be careful with synthetic oil as can cause clutch to slip
Old 27-07-11, 06:36 PM   #4
MJC-DEV
MJC-DEV's Avatar
Some car oils it is said. Bike full synth is safe for wet clutches.
Old 27-07-11, 06:36 PM   #5
Biker Biggles
Biker Biggles's Avatar
Have a look at the sticky at the top of this page.All you need to know.
Old 27-07-11, 06:45 PM   #6
Lucas66
so what i understand castrol power one fully synthetic is fine becaus eit exceeds jaso ma 2 and api sj
Old 27-07-11, 06:51 PM   #7
timwilky
timwilky's Avatar
TBH I wouldn't waste my money putting a full synth in an sv1000 lump.
But if you have the cash, who am I to suggest you save it.
Not Grumpy, opinionated.
Old 27-07-11, 06:52 PM   #8
Lucas66
there only seems to be a couple quid difference between the 2
Old 27-07-11, 09:04 PM   #9
power 1 is good if your abusing (racing) the motor.
I'd stick with the semi synth as there is not much between semi and fully
Old 27-07-11, 10:03 PM   #10
beabert
Only reason i dont use fully synth is because im tight
