Old 27-07-11, 09:59 PM   #1
beabert
Default Tachometer dial template
If any one wants this, here you go.
http://hotfile.com/dl/125184937/3450..._tach.cdr.html
You will need the free trial version of corel draw to open it. I made it pretty basic, but it fits. You could always tweak it yourself.
I used printable matt vinyl (Id use gloss if i did it again). I will be putting a uv reistant layer on it too.
I have actually messed mine up, i screwed it up too tighthly and it ripped. Also i rubbed some of the ink off by accident when cleaning it. But, it is good enough to give you a rough idea.
I was too tight to pay £19 for one from the url below, mine has cost me £1.50 so far.
http://www.cafepress.co.uk/sv650peeling.132537143
Tachometer clock for sv650x Terah Stuff Wanted 3 14-07-11 11:55 AM
Tachometer is down after CDI and battery died Cash SV Talk, Tuning & Tweaking 1 27-08-09 07:20 PM
Tachometer question from a noob lestat210 SV Talk, Tuning & Tweaking 4 22-01-08 10:58 AM
Tachometer died, where is the sensor? ELR4ever SV Talk, Tuning & Tweaking 4 22-01-08 07:34 AM
Tachometer problem Roorkee SV Talk, Tuning & Tweaking 0 25-07-07 06:20 AM
