Old 02-08-11, 10:59 AM   #1
Geese
Default ODO confused
I was reading that thread by Red herring about the MPG on an SV.
Most guys seem to get 120 - 150 miles from a tank before the light comes on
On my 2003 (carb curvy) I can get 225 on the trip meter before the light starts blinking.
Is this right? Seems a bit unreal. So I thought maybe the ODO/Trip is in KM which would be about right 225km ~ 140miles.
BUT My bike is a UK import and the Miles is the big number on the needle. So was there a way on the curvy to change the ODO/Trip from Miles to KM? Or could my bike be a french/euro mainland import?
Old 02-08-11, 11:17 AM   #2
Default Re: ODO confused
I don't think there is a way to change the trip from miles to km. It's possible to change the speedo face though.
Why not google map a route and then go ride the route, 100 miles makes the maths easy though you shouldn't need to measure many to show a 1.6x difference.
Old 02-08-11, 12:48 PM   #3
There isn't setting.
That sounds like a faulty board on the ODO, or as YC's hinting at the faces have been changed.
Quickest way to check if its a UK bike and not a Parrel is on Suzuki's website
http://www.suzuki-gb.co.uk/extra/onroad/000081/
Is is a naked or a faired bike, as I think most the euro bikes run with the left main lamp on (at dipped/ centre light on Faired only). May be talking s*** but one country does have that set up
Old 02-08-11, 01:08 PM   #4
Geese
Well i do know the speedo over- reads by about 5mph
I'll try the vin number on the site and see what it says. It's a faired bike and both lights run on it.
Old 02-08-11, 01:51 PM   #5
Speedo overreading a bit is normal
Old 02-08-11, 06:48 PM   #6
garynortheast
garynortheast's Avatar
I suppose it depends how you ride it but I regularly see 180 miles before the light starts flashing and I'm not that gentle on the throttle.
Old 02-08-11, 08:33 PM   #7
mpsricky
i happily got 140 til the light came on (not flashed) wasnt passing many petrol stations so didnt chance it lol
Old 03-08-11, 07:28 PM   #8
monkey
On the brightside, if the clock face has been changed then your mileage (in miles) is less than two thirds of what you thought it was!
Old 04-08-11, 12:28 AM   #9
myfirstsv
I bought a refurbed and recalibrated instrument cluster for my 02 650s (correct mileage) on the clock from this guy:
www.howmanymile.co.uk
He could probably turn your Odi into miles or tell you what the problem is.
Old 04-08-11, 08:15 AM   #10
Second this.
The guy is spot on. I do have a spare UK ODO kicking round circa 12k on it. £50 posted if you want to do a straight swap then look at them later.
The is normally a sticker on the top edge of the clocks the UK ones are 34119-20F21 (mph) To my knowledge there will be different part no for germany etc..
im confused :( Nicky S SV Talk, Tuning & Tweaking 21 01-03-09 08:32 PM
Confused! suzsv650 Bikes - Talk & Issues 5 27-05-08 12:16 PM
Confused..?? SVNez SV Talk, Tuning & Tweaking 3 10-08-07 05:31 PM
Confused.com Rocket Idle Banter 8 24-03-07 12:47 AM
I'm Confused Lissa SV Talk, Tuning & Tweaking 3 29-07-06 08:42 AM
