Old 07-08-11, 07:47 PM   #1
DJ123
DJ123's Avatar
Default Fuel Pump Relay
SV650S SK3
My fuel pump relay is not being energised when the ignition is turned on.
The fuel pump works and the relay works (i have tested them both)
I am not getting communication between the ECM and the relay telling it to start the pump.
Does any body know what it could be, or have had similar problems?
TIA
Old 08-08-11, 06:54 PM   #2
muzikill
muzikill's Avatar
Default Re: Fuel Pump Relay
once again get the official sv manual there is a detailed process for doing the fault finding test for this fault. ive done this exact test using it. my fault was the pump not priming therefore i had to buy a new pump. This fault has a multitude of possible key areas and it might not just be one thing.
k3 fuel pump assembly widget Stuff Wanted 0 13-05-10 12:23 PM
Fuel Pump Problem hindle8907 Bikes - Talk & Issues 2 29-11-09 01:34 PM
How do i remove the fuel pump on a K5 tonny006 SV Talk, Tuning & Tweaking 10 01-10-08 08:45 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
