08-08-11, 05:28 PM | #1 |
Oil preferences?
Im up for a service at any time now and just wondered what brands and specs (ie entry level to top quality) Oil peeps are using?, also with spark plugs is there a major diff between CR8E's and the CR9E's ? and does anyone have a preferred one out of the 2?
thanks |
12-08-11, 10:01 AM | #2 |
Re: Oil preferences?
I use Halfords motorcycle oil. It meets the spec that Suzuki recommend, plus I get 2 oil changes out of one bottle. My opinion, is, unless you are racing the thing, this oil will do the job. I do the oil and filter every 6k, and just the oil every 3k. Regarding spark plugs, not sure, but I fitted Iridium plugs to mine, as they are supposed to be better at cold starting.
18-08-11, 05:58 PM | #3 |
halford is good ^ also hein gerricke do a 4L tub and a free filter for 22£ which i have used for a few years in all my bikes inc the track bike
21-09-11, 02:17 PM | #4 |
Millers ZSS - £23.50 delivered from fleabay.
http://www.ebay.co.uk/itm/1706161344...84.m1439.l2649 Recommended by Bibio, bought by me!
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground" The Stoppy King
21-09-11, 08:33 PM | #5 |
Personally prefer to use Mobil 1 motorcycle oil as engine feels smoother and sounds quieter , also use NGK plugs and nothing else they tend to last longer CR9E
22-09-11, 03:52 PM | #6 |
CR7E is hot type.
CR8E is standard plug. CR9E is cold type. |
23-09-11, 05:59 PM | #7 |
Ive used only heine gericke oil and rock oil. Gearbox felt a bit smoother with the hein gericke stuff amazingly. Both semi.
I use iridium plugs so i dont have to change them as often |
24-09-11, 08:02 PM | #8 |
trying rock oil this year, having used motul past 2 years, seems to be using slightly less with the rock oil.
28-09-11, 08:32 AM | #9 |
Motul for me
28-09-11, 10:41 AM | #10 |
