Old 17-08-11, 06:55 PM   #1
muddydude
Default painted or powder coated wheels
come autum time i'm revamping my curvey.the wheels are a bit flakey and due for a coat or 2..what is best powder coat(I can get done cheap) or paint..cheers guys
Old 17-08-11, 07:03 PM   #2
ibanezlynx
Default Re: painted or powder coated wheels
Im going to be doing the same in the winter. People have told me that when the powder coating gets chipped moisture gets under and lifts the powder coat. I tried painting my own wheel but the paint and lacquer was weak. Im sure a professional paint shop would do a great job. However cost is a big part. Someone offered to paint both wheels for me for £200. Im not sure what the going rate is?
Old 17-08-11, 07:03 PM   #3
Dicky Ticker
Like you say---powder coating you can get done,alas not so lucky as you so it can be expensive.Alternatively you can spray paint wheels which is easier as not so specialised so DIY possible but also easier to repair any damage
Old 17-08-11, 07:20 PM   #4
beabert
Guy round my area specialises in powercoating motorcycles, done properly i thought it was stronger from what i read ill be getting mine done there, my front wheel is a mess.
Old 17-08-11, 07:31 PM   #5
I was £50 a wheel to get them powdercoated. I wouldnt say the finish was as nice as paint and you'll always have problems around the valve
Before I had them powdercoated I had the front sprayed by a top notch professional sprayer and the finish was perfect and not showing any signs of wear at all.
If I was getting them done again I'd get them sprayed
Old 17-08-11, 07:33 PM   #6
DavieSV
DavieSV's Avatar
Powder coat is harder and chips easier, it can also be pourous and let pressure escape from the tyre. Paint will scratch rather than chip and can be easily repaired.
To powder coat, you have to remove all the paint as this will bubble up in the oven and also remove bearings because the grease will melt in the oven and run out and the seals will melt.
Also when i had mine powder coated, I previously had polished rims and the brake dust had eaten into the aluminium and that left little bubbles in the powder coat at the baking stage which ruined the finish.
DavieSV is offline   Reply With Quote
powder coated front folk? david 1664 SV Talk, Tuning & Tweaking 2 04-07-10 08:18 PM
Powder coated Curvy torque arm maviczap For Sale - SV's and SV related items 0 26-06-10 10:13 AM
powder coated parts adam_castell For Sale - SV's and SV related items 4 19-02-09 09:55 AM
Getting a yoke painted/powder coated Flamin_Squirrel Bikes - Talk & Issues 12 03-02-08 02:49 PM
