Old 20-08-11, 09:11 AM   #1
lh25
Default Zx636 rear shock bolt
Hi just brought a rear shock from a 56 reg 636, before fitting does anyone know if i can use the existing bottom bolt or do i need a kwak part cheers
Old 20-08-11, 10:46 AM   #2
ixlr8
Default Re: Zx636 rear shock bolt
You need the Kwak bolt and nut. Then trim the head of the bolt so it doesn't rub. The 636 doesn't have a thread whereas the OEM does.
ixlr8 is offline   Reply With Quote
Old 20-08-11, 01:24 PM   #3
Winder
Winder's Avatar
There's an old thread on here somewhere with the part numbers for the two different length bolts. Have a search for it
Old 20-08-11, 05:13 PM   #4
Rob969
easiest thing to do is phone up a kwak dealer and order the bolt from them, thats what i did when i fitted my zx10 shock
ZX636 Rear shock on Curvy - adjustment? curvy custard SV Talk, Tuning & Tweaking 1 13-03-11 05:59 PM
Gsxr rear shock bolt - where from? g13unisol SV Talk, Tuning & Tweaking 25 03-02-11 08:06 PM
rear shock bolt GSXR pencil shavings SV Talk, Tuning & Tweaking 4 25-04-09 04:26 PM
ZX636 B1H Rear Shock mattc For Sale - SV's and SV related items 6 24-06-08 09:44 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
