Old 25-08-11, 06:15 PM   #1
sv_rory
Default oil seal replacement
How easy is it to replace the oil seal behind the sprocket?
I've had the bike laid up for months now and have decided to get it mots ready for the road however when i started it ( which it did first time on the button - well proud) all of the oil decided to exit out behind the sprocket,
I've ordered a new seal and O'ring but I'm a paint sprayer and panel beater by trade so not the best mechanic,
Any help much appreciated
Old 25-08-11, 07:50 PM   #2
muzikill
muzikill's Avatar
Default Re: oil seal replacement
do a search buddy, plenty of info in these forums including a wee tip i tried using liquid gasket. You never know it might work!
Old 25-08-11, 10:56 PM   #3
sv_rory
Sorted, it was actually a lot easier than I expected, I did it in just under 2 hours with a few little breaks
fork seal replacement price farquare SV Talk, Tuning & Tweaking 5 14-07-11 12:02 PM
Seal monster tactcom7 Idle Banter 7 04-10-10 01:32 PM
GSX GSF Transmission Oil Seal squirrel_hunter For Sale - Other Bikes and General biking items 4 09-05-10 10:26 PM
Fork Seal Replacement Luckypants SV Talk, Tuning & Tweaking 11 18-02-07 03:40 PM
Fork Seal Replacement Luckypants Bikes - Talk & Issues 1 17-02-07 07:11 PM
