Old 28-08-11, 03:05 PM   #1
Mykey.M
Default GSXR 400 GK76a rear shock
does anybody have any knolage of a rear shock that fits straight into the gk76a?
i dont really need might do i need a deffo yes
i will be buying one that will fit for sure and i need to no,
anything like other 400's or 250s?
cheers
Old 28-08-11, 03:11 PM   #2
suzukigt380paul
Default Re: GSXR 400 GK76a rear shock
ever thought about fitting a gsx400 shock on it,just a thought,and im fairly certain it will fit
some dimensions might help,what size holes on end of shock,and what does each end look like and what distance centre to centre,so how long is the shock
Old 28-08-11, 04:50 PM   #3
BBadger
whats wrong with its? rebuild maybe, would be cheaper.
im half way through doing my dr one...and tbh a shocks a shock and i know the res if different on the gsxr400 but not by much.
might pick up a few tips here
http://www.maximum-suzuki.com/forums...?topic=70150.0
and if you wanted a new spring
http://www.dfaulknersprings.com/
uk based and not that expensive either.
Old 28-08-11, 04:52 PM   #4
A lot of these older shocks don't have nitrogen valves so you have to retrofit one or use a different res end cap or something. Slight spanner in the works but not much.
Old 28-08-11, 05:18 PM   #5
Try and get a GK76 SP shock, they were different to a Std 76 and a lot better spec overall
Old 28-08-11, 08:49 PM   #6
garynortheast
garynortheast's Avatar
Most of the 400 gixer shocks weren't really rebuildable.
I do know of someone who has managed to fit a fully adjustable Showa rear shock from a cbr1000 to his 1991 76a although it was a tight fit and some modification was needed. It apparently works well. I believe that the shock from a K4 1000 gsxr also fits.
Hagon and Maxton can do new replacements for you too.
Old 29-08-11, 04:27 PM   #7
Mykey.M
do you know what mods had to be done to get it to fit?
or would you be able to find out how?
i like thatg idea alot
its got a sp rear shock in it already because the original broke, but the sp one failed the mot for no damping so was going to get it re gassed and some **** before me put a ally valve cap on the vavle abd it all corroded and i snapped it off :/ and i cant get the right valve to fit anywhere!
Old 29-08-11, 06:08 PM   #8
You had a look on the 400greybike forum?
gsxr 600 rear shock stamasman For Sale - Other Bikes and General biking items 1 18-10-10 01:31 PM
GSXR rear shock for K3 marcosa SV Talk, Tuning & Tweaking 2 29-09-10 10:55 PM
GSXR 750 rear shock Zubanoid SV Talk, Tuning & Tweaking 19 02-10-08 08:26 PM
GSXR 600 K1 Rear Shock Swiss For Sale - SV's and SV related items 0 30-01-07 09:31 AM
GSXR Rear Shock....! bobit69 SV Talk, Tuning & Tweaking 18 06-03-06 12:31 AM
