Old 31-08-11, 10:10 PM   #1
Winder
Winder's Avatar
Default Rear brake hose
The hose going from my rear brake reservoir to the master cylinder on my k2 curvy is dry and cracked and needs replacing. I've seen bikes with what looks like clear rubber tubing in it's place. Can you use any similar thickness tubing or must it work to a specific pressure?
Old 31-08-11, 10:15 PM   #2
hardhat_harry
Default Re: Rear brake hose
HRC Brake Tube kit or Equivalent (See Yorkie Chris)
Stopper needs a breathing hole
Some say the HRC kit sweats but I have had mine on for 3 years been used in November at an icy Oulton to use in Spain in +30 C at Almeria with no sweating.
There has been a suggestion there are fake HRC kits out there I got mine from Jap performance in HRC packaging.
The tubing is special otherwise the brake fluid will react.
Old 31-08-11, 10:20 PM   #3
Winder
Winder's Avatar
Thanks for the fast reply, I'll get reading up on it
Rear curvy brake hose paiste Stuff Wanted 3 22-09-10 11:41 AM
Rear brake hose - Curvy & Pointy the same? ging6996 SV Talk, Tuning & Tweaking 1 14-02-10 10:52 AM
Rear Brake hose svdemon SV Talk, Tuning & Tweaking 8 19-08-08 10:37 PM
Rear brake hose husky03 SV Talk, Tuning & Tweaking 9 09-11-07 08:28 PM
Rear brake hose clip thingy oldjack SV Talk, Tuning & Tweaking 2 09-03-07 11:35 PM
