Old 14-09-11, 10:12 AM   #1
SV650SF
Default Naked conversion
Hi all,
Sorry if this has been asked before....
I'm looking at a 2002 Sv650s but it's not a naked bike, I want to turn it into the naked version/street fighter look.
My question is, when I start removing the faring will I be left with unsightly brackets on the frame etc?
Also.... how do I go about raising the bars?
Lee
Old 14-09-11, 10:23 AM   #2
TamSV
TamSV's Avatar
Default Re: Naked conversion
Brackets won't be your problem - they're all removable.
Hiding all the excess wiring will be where the pain is. Lots of other things to solve - fitting clocks and lights for example - there's a variety of choices.
For the bars, you can try and find the top and bottom yokes from a naked bike (although you'll be lucky - they're like hen's teeth). Alternatively, some have drilled the existing yoke to fit risers.
Do a forum search. It's been done and discussed many times on here.
Old 14-09-11, 11:09 AM   #3
DJ123
DJ123's Avatar
best to buy a naked bike to begin with, far easier to convert it rather than turning an S into a naked. Nakeds are cheaper to buy and cheaper to insure
Old 14-09-11, 09:09 PM   #4
Winder
Winder's Avatar
Where bouts are you? Someone could lend you a hand when you get the bits and bobs. The vapour clocks look pretty sweet, bandit clocks have been used as well. As for the loom, just hide it under the tank with some ninja zip tie action. Lights can be sourced on the bay depending what style you want.
I would either drill the yoke or if your feeling rich get the comfort kit for the curvy as this will have the longer throttle and choke cables you need
Old 14-09-11, 09:12 PM   #5
-Ralph-
Bollox. Thought this said 'Naked conversation', and was expecting something interesting...
PM Yorkie_Chris, he's just done a curvy naked conversion for his girlfriend, our very own MissYorkie_Chris.
Old 15-09-11, 01:31 PM   #6
Do this - this is the best advice.
Old 16-09-11, 12:30 PM   #7
tweakedtay
Originally Posted by SV650SF View Post
Hi all,
Lee
Agree with everyone else. Why do you need the S when you're just gonna rip off the plastics? Pretty sure the standard and the S have no performance differences.
Old 16-09-11, 01:41 PM   #8
-Ralph-
The naked is actually slightly quicker on acceleration at lower speeds, as it has lower final drive gearing ratio. That negates at higher speed due to aerodynamics.
Old 16-09-11, 01:57 PM   #9
tweakedtay
I had no idea! I though they were the same, minus plastics and therefore a little weight. I can't see the difference being that noticable. In a race, it would probably come down the rider, not the bike.
2nd Gen Naked to S front end conversion Wonderfulness SV Talk, Tuning & Tweaking 5 12-01-19 07:39 PM
Naked Conversion plowsie Bikes - Talk & Issues 43 21-05-08 01:10 PM
I wished I'd gone naked, I need a bar conversion methinks. Taipan SV Talk, Tuning & Tweaking 28 03-05-07 06:59 PM
06 Naked to S conversion 007SV650 SV Talk, Tuning & Tweaking 7 21-04-07 12:10 AM
Faired to naked conversion?? Lucky Luke SV Talk, Tuning & Tweaking 11 06-08-06 06:16 PM
