Hardware Post your own reviews, opinions and experiences on this subject.
Old 14-09-11, 12:08 PM   #1
missyburd
Default Hot grips
Anybody use/recommend any others apart from Oxford? I need to start preparing the SV for winter, it's going to end up with handguards also because my silly little hands can't cope with cold but I just wondered if there were better grips than Oxford?
Cheers in advance,
Maria.
Old 14-09-11, 02:09 PM   #2
metalhead19
Default Re: Hot grips
Why not oxford?
Old 14-09-11, 02:12 PM   #3
missyburd
I know Oxford are good and readily available but wanted to know what other options are. If it meant I had to spend a bit more for a better quality grip then it would be worth it.
Old 14-09-11, 02:21 PM   #4
rictus01
rictus01's Avatar
the oxford ones tend to have a problem with the digital control unit, the daytona simple rotating one I find much more reliable.
And rather than handguards, these work much better for even the worst climate conditions, not trendy I'll grant you, but functional (make sure you get the neoprene ones.)
Cheers Mark.
Old 14-09-11, 02:32 PM   #5
missyburd
Yeah I'd heard about the Daytonas, any feedback on those would be good.
I'm not too sure about bar muff things, I just keep thinking there'll hamper the controls.
Old 14-09-11, 02:37 PM   #6
rictus01
rictus01's Avatar
I've used the daytona one's for 3 winters (that's about 40k winter riding) without any issue, the bar muffs can get it the way a bit, I'll grant you, but the neoprene one's are better as they retain their shape more, they are 10x better than handguards if heat is what you're after, with the combination of the two I've never had cold hands even with ice buildup on the outside of the muffs, miles done and Rictus tested.....
Old 14-09-11, 02:44 PM   #7
missyburd
Rictus tested.....
A certified guarantee if ever there was one!
I may try them out in that case. Do you know if they only come in the one size though? If they be too big for my hands then that will add to the cumbersomeness even more, not ideal...suppose for £20...
Old 14-09-11, 02:54 PM   #8
timwilky
timwilky's Avatar
Rather than heated grips, I bought heated gloves. Absolutely marvellous, hands like toast, come spring I had serious issues that I did not want to give up the warmth until they became uncomfortably hot.
Not Grumpy, opinionated.
Old 14-09-11, 02:57 PM   #9
missyburd
Duly considered, unfortunately funds don't stretch that far.
Old 14-09-11, 03:02 PM   #10
kellyjo
MYC, Ive used the muffs alone for the last two winters and ridden only in my summer gloves. I only remember one occasion when my hands got too cold, but it was a seriously cold day with ice on the road. After a couple of trips id forget the muffs were there and never had a problem with them interfering with the controls.
This winter I have heated grips too!!
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
Gel Grips SAMMY650 SV Talk, Tuning & Tweaking 3 10-07-08 09:36 AM
SV Gel Grips RRP £14.99 Yours for £13.00 SAMMY650 For Sale - SV's and SV related items 0 08-07-08 11:00 AM
Hot grips yorkie_chris SV Talk, Tuning & Tweaking 18 02-11-07 10:18 PM
Better grips for SV TSM SV Talk, Tuning & Tweaking 6 21-07-05 11:01 AM
