Old 29-09-11, 09:19 PM   #1
littleoldman2
littleoldman2's Avatar
Default Newcastle to Kinlochleven loop
Hoping to do this this weekend. I'm happy with the route up, but route home seems a bit lame from Glasgow to home problem is I need to ride south east and all the roads run south west from Edinburgh. Any suggestions,
route out
http://maps.google.co.uk/maps/ms?msi...10646,5.817261
route home
http://maps.google.co.uk/maps/ms?msi...c7b190af&msa=0
Cheers Mal
Old 29-09-11, 11:36 PM   #2
Tiger 55
Default Re: Newcastle to Kinlochleven loop
South out of Glasgow (b*llocks to Edinburgh) to Carluke then across to Peebles and Jedburgh, or a cheeky right at Selkirk down to Hawick. All roads lead to Carter Bar...
Linky?
It's a bit all over the shop in terms of road numbers - A72/A71/A70/A721/A72/A707/A7 - but keep heading south east and you'll stumble over the A68 eventually
Old 30-09-11, 12:11 AM   #3
There:
http://maps.google.co.uk/maps?saddr=...,2,3,4&t=m&z=8
Back:
http://maps.google.co.uk/maps?saddr=...,7,8,9&t=m&z=8
Old 30-09-11, 07:06 PM   #4
littleoldman2
I'm planning on doing this in one day ( tomorrows forecast is good) route there looks good, cuts out the boring bits, but misses out on dukes pass. I'll go with your local knowledge many thanks. Undecided about the route back as will mean the ride from around Jedburgh will be dark and a long day. Will put all three routes home in the sat nav + on a bit of paper will see how time goes. Thanks to Bibio and tiger 55
Old 30-09-11, 07:31 PM   #5
your keen m8. that amount of miles on scottish roads in one day. even i'm not that mad. as for the dukes.. its good but after doing that amount of miles you might be a bit weary so best not as it can be full of coaches and flat caps.
Old 30-09-11, 07:50 PM   #6
littleoldman2
"full of coaches and flat caps." best kept for a weekday then. Know the road back to the M8 and A68 / A7 Castle Craig to home well. Will see how it goes, but if I'm all in, can always take the M74 / A69 or M8 / A1 home.
.Avi continuous loop ? hindle8907 Idle Banter 1 16-09-10 02:40 PM
Euro loop version 1.00 Whynot EuroTour 13 24-04-09 09:20 AM
Kinlochleven Skyeblue SV Ecosse 32 18-09-07 09:20 PM
