Old 08-10-11, 01:05 PM   #1
Jason-m
Default Hugger fitting help
Trying to fit a new pyramid hugger on my 07 K6 pointy,its on a paddock stand and rubbing a little bit when i turn the wheel, but the bracket can't go forward anymore where it need to because of the rear brake hose clamp, has anyone fitted one and how did you get round this...?
Old 08-10-11, 01:20 PM   #2
Jason-m
Default Re: Hugger fitting help
UPDATE.....i have removed th clamp and slid the bracket forward over the screw hole where the clamp was...obviously the clamp can't go back on, newbie question...can i just hacksaw the clamp off and be done with it..?
Old 08-10-11, 04:11 PM   #3
Epic Monkey
Hey
I have the same issue with a hugger I bought for my 61
Reg sv. After deciding not to cut the hose bracket I spoke to my dealership today and they suggested screwing the hose clip into the bracket. This sounded sensible but I haven't had a chance to check if it will work.
Quick question. Does your bracket fit your swingarm? Mine fits on. But when I tightened it, there is about an inch at the bottom so it is not snug enough to prevent moving.
I'll try post a pic if I can.
Old 08-10-11, 04:46 PM   #4
Jason-m
I ended up cutting the hose bracket off as it was the only way i could stop the hugger from rubbing, mine fits snugly, have added a pic
Could not screw the bracket into mine as if you see on the pic non of the holes on the bracket are on the arm
Old 08-10-11, 05:03 PM   #5
Epic Monkey
Good work. I think my hugger is not the correct one for my bike. I've seen on the pyramid website that there are 2 versions. 1 for black swing arms and 1 for silver. My bracket is silver and after seeing your pic you have a black bracket. Damn. Need to eBay a hugger now and buy another one.
Old 08-10-11, 05:08 PM   #6
Jason-m
I was unsure which one to get off pyramid myself, thankfully i got the right one...hope the sale goes well
Hugger fitting? Morrag SV Talk, Tuning & Tweaking 0 26-05-11 05:36 PM
Hugger fitting? bigchris SV Talk, Tuning & Tweaking 8 13-12-10 01:40 PM
Fitting a hugger. 7755matt SV Talk, Tuning & Tweaking 6 31-08-09 08:07 PM
Fitting a Hugger K4 DanDare SV Talk, Tuning & Tweaking 3 17-08-06 02:09 PM
fitting suzuki oem hugger walnuts SV Talk, Tuning & Tweaking 6 22-06-06 11:17 PM
