So I've got my bike in my old man's garage having highsided at Rockingham on Friday...
![]() I need:- RH foot peg ![]() Front brake reservoir and whatever connects it to the lever as this is sheared off. Not sourced a spare yet? RH indicator (had the small carbon fibre look type but will replace both if cheap alternative found) RH mirror Right hand clip on needs moving back round. The locating pin has sheared off but hopefully I can live without it? ![]() The rear brake lever is bent towards the body. I'm going to attempt to heat this up and bend it back if that sounds reasonable? ![]() The front fairing is pretty ground down and thus the light fitting is a tad loose but in one piece. Not sure whether to just gaffer tape it all together and live with it for now or I've heard people talking about plastic welding? Any ideas? Also the fuel tank is scratched. Not sure if I'm fussed about a full respray but obviously concerned about rust proofing it. Any ideas how to achieve this? I'll try and post some pics and then look around in the spares forum. Cheers. Last edited by Stenno; 11-10-11 at 07:54 PM. |
The brake leaver can be re-shaped, make sure you heat it up with a blowlamp and take care bend it in small stages otherwise it will fracture, i would suggest finding a new clip on off ebay my LH clip on lug had sheared off i rode it like this for a while but i wouldn't recommend anyone doing so just incase
i've got a RH clip on, it is slightly bent downards so its very clsoe to the tank on full RH lock. Maybe good enough to do you for now. They are cheap on ebay for £20 a pop
Cheers Daddyjob, I'll move mine round first and inspect it. I don't think it's bent thankfully.
I have been riding my bike for 4 years using clip ons with no locator screw/grub/pin. As not affected me at all and I ride like a twunt! It'll only move in an accident situation so I wouldn't worry about it.
Gaffer tape the Front cowling and keep your eye on ebay for a better condition one going on the cheap. That;ll be expensive to fix as the whole side will need reshaping after it is stuck back together and not worth the effort IMHO. Front brake master cylinder can be had for 20 quid on ebay usually, so will be cheap enough to replace. Just clean up any loose paint on the tank and use some touch up paint to protect it until you decide what your gonna do. You'll be back on the road in no time, all be it on a bike that looks a little sorry for itself! |
Ha, I reshaped my brake lever on my old bike using just a hammer.
It went very well. But yeah, heat it up if you can |
Cheers for the advice Phil!
I've ordered new mirrors and indicators. Just searching ebay for the front brake master cylinder and foot peg. I'll touch up the paintwork and gaffa tape the cowling as suggested. My dads a plumber so I'll borrow his gas torch to heat up the brake lever and hit it with a hammer! |
Don't hit it, bend it (a vice will help). By hitting it you will risk breaking it. If you have nothing to bend it with then hit it gently!!!
#9 |
haha will do! Cheers
#10 |
*like*
Found a lid yet? |
Crash.NET - Vermeulen recovers to fifth after highside. | NewsBot | News | 0 | 01-09-08 12:50 PM |
How to recover from a highside | SoulKiss | Bikes - Talk & Issues | 10 | 22-04-08 05:13 PM |
Highside! | Blue_SV650S | Bikes - Talk & Issues | 57 | 07-02-08 01:59 PM |
Crash.NET - Hopkins 'beat up' by 120mph highside. | NewsBot | News | 0 | 16-02-07 03:16 AM |
Highside recovery | Supervox | Idle Banter | 9 | 22-05-06 09:06 AM |
