Mini-Twins Goto Minitwins Official Site
Old 17-10-11, 07:37 AM   #1
joolski
Default Brakes - some advice required
Hi All,
I've recently got myself a MiniTwin race bike, last week I completed my 3rd test session at Mallory since owning the bike. Things are going nicely, and I've got the bike setup for my lanky frame (6foot 4inches), and it's starting to feel pretty planted.
However, as with all things racing as soon as you go faster, there is always the increased need to stop ! Which is where I'm coming unstuck.
I think the bike has stock disks and lever, but hel brake lines, but after a few hours on the track I'm having to bleed the brakes to get some brakes back !
Is this normal ? Also, what do other racers do ?
Cheers !
--Jools
Old 17-10-11, 10:50 AM   #2
Matty Boy
Default Re: Brakes - some advice required
Hi there mate,
Im new to the minitwin game too and in a pretty similar position! This is one area I have been suffering with on track!
Up untill recently I had been using EBC sintered pads, but now ive been finding some more pace I just cant get on with them! They seem to act like an on/off switch with no mid range feel, and in heavy braking areas feels as tho the front will lock up.
I switched to Performance Friction pads and for me, they transformed the bike! They give me alot more confidence to brake later.I am not a front runner so I cant talk for the top guys, so I can only speak from the point at which im at now.
I have standard calipers and discs under the minitwin regs.
Hope this helps.....Matty Boy
Old 17-10-11, 12:19 PM   #3
RGV500
I'd recommend the PF pads too they transformed the braking on my MT.
Old 17-10-11, 12:19 PM   #4
I'm tempted to say you've either boiled your brakes or have a loose bolt on the M/C or calipers
What pads you got on the bike?
Old 17-10-11, 02:10 PM   #5
coxxy
A common problem on these brakes really designed for stopping on an orange traffic light!
It was a similar case with ours two seasons ago, lots of fade and lever to bar problems leaving a concerned rider.
It took the following to get them as hot as was needed to run at the front of the MRO pack:
1. PF pads with 2mm+ wear left
2. Hel lines, blue preferred
3. Racing blue or top spec brake fluid (SRF Racing)
4. Spotlessly clean internals on calipers and master cylinder, blown through with air lines or brake cleaner
5. Polished pistons in calipers, mirror finish
6. New seals on caliper and master cylinder
7. Spotlessly clean caliper externals for good heat loss
8. System bleed at top banjo joint (double banjo bolt with bleed nipple helps)
9. Removal of dust seals on calipers and pre use clean over with brake cleaner including discs
10. Stock brake discs with no warping and min thickness + left on wear, keep dust free for good heat loss
11. Disc bobbins in good condition
12. New fluid every 3 race weekends
Keeping all this in tip top condition and the brake pads will wear and profile onto the disc gaining more and more bite, the lever will become stiffer and stiffer after each bleeding cycle with no fade at all eventually possible.
Hope this helps!
coxxy
Old 17-10-11, 08:31 PM   #6
joolski
Hope this helps!
coxxy
Excellent advice ! Many thanks for taking the time to write all this up, very useful.
Cheers !
--Jools
Old 17-10-11, 10:28 PM   #7
Sy-superfly
I was going to post a thing up about pads where do you get the PF pads?
Old 18-10-11, 06:34 AM   #8
PM SV650Racer
Old 18-10-11, 09:25 AM   #9
Whitty
I had same probs on my gsxr600 srad. Hel lines, ebc pads, bigger piston m/cyl off 750 etc. Rebuilt calipers and tried SBS race/track pads and thought it was sorted till five laps in at cadwell and lever starts coming in to bar! Kept pumping lever then tying with an elastic band to get any minute bubbles out between sessions and it would be ok for about 5 laps again. It turned out to be master cylinder seals off my 'bargain' mod m/cyl from ebay. They looked ok but new kit transformed them. As for ebc pads try SBS ones (track not road obviously). Ithink they are excellent and cheaper than pf if you shop around. There is a chap sells them on ebay, I will try dig him out.
Old 18-10-11, 12:41 PM   #10
coxxy
PM SV650Racer
I wouldnt buy them there (cost quoted 103.30 pair) too expensive, go here:
http://www.ebay.co.uk/itm/Suzuki-SV-...item3367676d23
Lots cheaper at 85.50 including express postage.
These PF Pads last a lot longer and are usually good for at least 3 race weekends but worth the extra cost over others.
Forgot to add, buy genuine Suzuki seals not cheaper copies.
Front brakes - advice please hongman SV Talk, Tuning & Tweaking 33 27-07-11 09:10 PM
Brakes.. General Help/Advice Needed! Sally SV Talk, Tuning & Tweaking 7 28-01-10 04:55 PM
Changing Brakes and Lines. Advice please. Diveboy SV Talk, Tuning & Tweaking 11 10-04-06 02:08 PM
Urgent help required with brakes empty SV Talk, Tuning & Tweaking 4 21-03-05 07:20 PM
Brakes: help/advice needed Anonymous SV Talk, Tuning & Tweaking 8 24-09-04 10:36 AM
