Old 25-10-11, 12:46 PM   #1
Robw#70
Default Breaking Carby SV700 thunderbike
Carby SV700 parts inc:-
Carb engine with injected clutch cover, 700 kit, sigma slipper clutch (I will be taking generator, rocker covers and gear pos switch off) Offers?
41mm FCR Flatslides with filters, adapters and cables £500
Brembo 19x20 mastercyl (tatty but useable) £100
SES 50mm billet clipons £40
Triumph 675 fairing and seat, with alloy fairing bracket and steel subframe to suit (has some crash damage but repairable) £100
Sprint steering damper with clamp to suit gsxr forks (53mm fork clamp) straight but needs service £40
07966-280851 after 6pm
Old 31-10-11, 08:22 PM   #2
Robw#70
Default Re: Breaking Carby SV700 thunderbike
clutch, carbs, master cyl, front end now sold
Old 07-11-11, 01:48 PM   #3
Robw#70
Right after being messed around for ages I still have for sale:-
Brembo master cylinder, graze on lever and body but still perfectly useable £100
Sigma slipper clutch, wear on hub and pressure plate but still useable £300
50mm clip-ons billet clamps (different style L+R) tubes straight £40
Carby engine with 700 kit (need to check cams prob injected ones) missing rocker covers, generator and neutral switch £300
sprint steering damper 100mm stroke and 53mm clamp needs service £40
triumph 675 fairing and seat with brackets (alloy clock brkt) and modified steel subframe, damage to lhs but only cracks £100
mail:- r wittey at yahoo . co . uk
Old 17-11-11, 05:28 PM   #4
Robw#70
bump!
Old 19-11-11, 11:56 PM   #5
Serdna
What cams are on that engine? Im looking to uprate my curvys cams. Also what is this 700 kit you speak of? Is it just a different piston or is there more to it? Also do u have any Dyno results from the engine?
Old 20-11-11, 09:45 PM   #6
Robw#70
Not sure on the cams, think theyre injected onnes, need to check numbers, I think the 700 kit is JE pistons, but dont belive the hype ive ran wiseco's with no problems in the past and I believe my 700 motor from 2006 is still going strong.
I did run the bike, but it had a coil problem so missfired over 7k, still made over 80hp though
Old 28-11-11, 09:35 PM   #7
Robw#70
Remaining bits now on ebay:-
http://www.ebay.co.uk/sch/071275rob/...id=p4340.l2562
First project... Thunderbike! Chris Bird SV Talk, Tuning & Tweaking 22 03-02-12 07:38 PM
SV700 Anyone? thedonal SV Talk, Tuning & Tweaking 9 03-12-07 11:28 AM
SV700 Championship winning Thunderbike Robw#70 For Sale - SV's and SV related items 1 12-10-07 03:36 PM
Sv650 Minitwin/thunderbike, Race winning bike for sale andyrs For Sale - SV's and SV related items 4 19-09-07 05:27 PM
SV700 Thunderbike Robw#70 For Sale - SV's and SV related items 7 13-09-07 09:11 PM
