Old 31-10-11, 02:47 PM   #1
Default Car mechanics.... what is this thing?
This was hanging loose in the engine. So I plugged it back in. Good or bad? And what is it?
It's a 1.4 mk4 golf
Old 31-10-11, 02:51 PM   #2
Default Re: Car mechanics.... what is this thing?
Plug for the flux capacitor?
Prob not a good idea it being unplugged, might fill up with water.
Old 31-10-11, 03:06 PM   #3
stormingjoe
stormingjoe's Avatar
Timing hole for the flywheel.
Podgey on a bike
stormingjoe is offline   Reply With Quote
Old 31-10-11, 06:21 PM   #4
Bluefish
That there hole is where they put the hampsters in that make the engine go around, they have probobly all escaped now so you had better get down the shop and get some more, hth.
Old 31-10-11, 07:38 PM   #5
Messie
The Teacer
Messie's Avatar
It's the green thingy that sometimes goes in the whatsit!
Old 31-10-11, 07:52 PM   #6
I'd go with that, it's on the bellhousing inside of which is the flywheel, which in turn is a common place for timing marks to be found.
Old 31-10-11, 07:56 PM   #7
It's where you put the petrol or engine oil, either will do
Old 31-10-11, 08:06 PM   #8
Berlin
Its where you put the sawdust, just before you sell it
Old 31-10-11, 08:12 PM   #9
husky03
its the port for the reg/rec-yours is missing it so i'd recommend the honda upgrade
Old 31-10-11, 08:15 PM   #10
SpikeTM
It's the cap for flywheel locking pin for when fitting timing belt the cap is only to keep all the s**t of the day out
Any car mechanics on here? Electro Idle Banter 12 22-07-10 07:23 AM
Any vechile mechanics or learning mechanics? ManxMatt34 Idle Banter 23 06-11-09 08:27 AM
Any car mechanics..... arcdef Guildford Massive 6 17-09-09 07:05 PM
Any car mechanics.... arcdef Thames Valley 2 16-09-09 07:26 AM
Any car mechanics out there? flymo Idle Banter 10 01-02-09 01:03 AM
