Old 31-10-11, 03:59 PM   #1
adam_castell
Default breaking SV650S curvey 2001 in pearl lively yellow 20k miles
ALL SOLD NOW, NOTHING LEFT
I am moving house at the end of december and do not have the space to hold on to this lot now, so i need the whole lot gone before then, i want £300 collected for the lot.
breaking an SV650S curvey 2001 in pearl lively yellow 20,000 miles on bike
i have been meaning to relist these parts for a while, the list should be fairly accurate, but i will go through and update soon.
the bike was dropped, damaged to screen, rh upper, lower fairings, brake pedal, exhaust can, rh footpeg, and rh indicators. everything else is in good nick
all the stuff availible is listed below, nothing else is avalible apart from bolts and screws (although i may have forgotten to list some bits)
collection is welcome and is from dunstable
contact me via PM for bulk discounts,
i will remove items from the list when i have recieved payment.
payment by cheque, cash, paypal, or bank transfer
although i will take payment via PAYPAL, but please slecet to cover the fees yourself
please write down which items you have brought when sending payment and you postal address if applicable.
i will post items on saturdays, and only items paid for by the end of thursday will be packed ready for me to post on saturday.
http://img.photobucket.com/albums/v7...DSC00137-1.jpg
http://img.photobucket.com/albums/v7...l/DSC00151.jpg
http://img.photobucket.com/albums/v7...l/DSC00152.jpg
http://img.photobucket.com/albums/v7...l/DSC00153.jpg
http://img.photobucket.com/albums/v7...l/DSC00154.jpg
http://img.photobucket.com/albums/v7...DSC00155-1.jpg
http://img.photobucket.com/albums/v7...l/DSC00156.jpg
http://img.photobucket.com/albums/v7...l/DSC00157.jpg
http://img.photobucket.com/albums/v7...l/DSC00164.jpg
DESCRIPTION ---- PRICE + P&P
haynes manual 99-02 £7.50 £2.50
airbox £10.00 £5.00
axle front £5.00 £3.00
axle rear, axle nut, and washers £5.00 £3.00
bar end weight £2.50 £2.50
brake callipers front£50.00£10.00
brake light assembly£15.00£4.00
brake master cylinder front & reservoir£15.00£3.00
brake master cylinder rear & reservoir£10.00£3.00
brake switch rear and spring£5.00£3.00
brake torque arm£5.00£3.00
clip-on LH£10.00£3.00
clip-on RH£10.00£3.00
clock surround£20.00£4.00
clocks (with 20,000 miles on the clock)£40.00£5.00
clutch cable£5.00£2.50
clutch lever£10.00£3.00
coolant reservoir £5.00£3.00
exhaust headers set standard£30.00£15.00
fairing bracket LH upper£2.00£2.00
fairing tail piece£10.00£3.00
fairing upper RH (scuffed and cracked)£5.00£6.00
fan£15.00£5.00
fork springs standard, from bike with 16k miles£10.00£5.00
forks, hagon progressive springs fitted, rebuild and new oil at 16K (has normal corrosion on fork legs)£100.00£20.00
frame, swingarm, and linkage 2001 private plate KAZ 9931, V5, number plate included£120.00£40.00
gear pedal£30.00£4.00
grab rail£10.00£4.00
headlights£40.00£6.00
heel plate LH (some marks)£5.00£2.50
heel plate RH (some marks)£5.00£2.50
horn£5.00£3.00
ignition coil F£5.00£3.00
ignition coil R£5.00£3.00
indicator rear LH (brand new)£20.00£3.00
indicator rear LH (slight scuff)£2.00£3.00
indicator rear RH (slight scuff)£2.00£3.00
lock set (3 x locks and 2 x keys)£50.00£5.00
mirror infill panel LH£3.00£2.00
mirror infill panel RH£3.00£2.00
mirror LH (few marks)£20.00£5.00
mirror mount spacers pair£5.00£2.50
mirror nuts£5.00£2.00
mirror RH (few marks)£20.00£5.00
mud guard mounting brackets and bolts£5.00£3.00
mud guard £30.00 £5.00
parking / side light£5.00£3.00
pillion / exhuast hanger RH£15.00£3.00
pillion foot peg LH£5.00£3.00
pillion hanger LH£15.00£3.00
pillion seat £25.00£5.00
radiator temp sensor£5.00£3.00
riders foot peg sensor bolts (3 avalble price each)£1.00£1.00
seat catch mechanism£5.00£3.00
side infill panel LH£5.00£2.50
starter motor relay£10.00£3.00
steering stem nut£5.00£2.00
subframe front£20.00£10.00
subframe rear£30.00£20.00
switch gear LH£10.00£3.00
tail tidy suzuki oem (damaged, but repairable)£10.00£10.00
throttle cables£5.00£3.00
undertray standard£15.00£8.00
vacuum fuel pump£15.00£3.00
vacuum fuel valve£10.00£3.00
wiring loom£25.00£5.00
yoke bottom, stem, bearings£15.00£5.00
ENGINE HAS SOLD
Old 31-10-11, 04:06 PM   #2
HoL
Default Re: breaking SV650S curvey 2001 in pearl lively yellow 20k miles
Are you selling the hugger?
Old 31-10-11, 04:12 PM   #3
adam_castell
i have a feeling that has gone, but i will check for you
THERE IS A GOOD CHANCE THAT IF THE ITEM IS NOT ON THE LIST THEN IT HAS GONE
Old 31-10-11, 07:38 PM   #4
myfirstsv
By the brake light assembly do you mean the black thingy that hangs over the number plate and lights it up? If it isn't do you have that bit?
Old 31-10-11, 07:40 PM   #5
adam_castell
i think your after the number plate light which i do have -
number plate light £5.00 £3.00
Old 31-10-11, 07:50 PM   #6
myfirstsv
Sent you a pm
Old 01-11-11, 10:17 AM   #7
Taipan
Taipan's Avatar
side infill panel RH£5.00£2.50
Is that these little black panels with the vents in? If so I'll take both of them please.
Old 01-11-11, 10:30 AM   #8
adam_castell
yes that is what they are, i will dig them out for you.
Old 01-11-11, 10:50 AM   #9
Taipan
Taipan's Avatar
Cool. PM your paypal address and I'll send over the cash. I put it as a gift so you avoid the fees right?
Old 21-11-11, 08:18 PM   #10
adam_castell
breaking SV650S curvey 2001 pearl lively yellow adam_castell For Sale - SV's and SV related items 76 30-09-10 07:55 PM
SV650S, Year: 2001, Only 12572 miles, Pearl Canyon Yellow, excellent condition trickster For Sale - SV's and SV related items 12 20-08-10 11:19 AM
Touch-up paint pearl lively yellow Old Git Stuff Wanted 7 09-05-09 12:51 PM
bits for curvy k2 pearl lively yellow 2002 cymroboi Stuff Wanted 2 16-02-09 05:09 PM
2 cans of pearl lively yellow Y9H paint adam_castell For Sale - SV's and SV related items 4 27-11-07 03:11 PM
