Old 02-11-11, 08:52 PM   #1
phi-dan
phi-dan's Avatar
Default Sprint ST fuel connector
Long story short, but I just helped a mate swap out the spark plugs on his (new to him) Sprint ST 955 and one of the fuel connectors snapped off (I barely touched it - honest ).
As far as I can tell, this ought to have been replaced under recall, but it looks like a previous owner didn't bother.
The local dealer wants to replace the whole fuel plate assembly, but surely the part is available separately?
The top connector is the one that is bust
Is that number 7 (part PFKL1199484) on this fiche?
Thanks in advance for advice and general mocking
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 02-11-11, 10:18 PM   #2
svian
Default Re: Sprint ST fuel connector
Yes Part no. 7 looks like it. You can get them on there own as I did when I broke mine on a T595. Got from my local dealer Carl Rosner. Have a look on www.t595.net as there are alternatives made from metal which are much better. the recall only changed the connector on the actual fuel pipe for metal ones. The tank sockets were never part of it. Hope that helps?
Old 02-11-11, 10:37 PM   #3
phi-dan
phi-dan's Avatar
Cool thanks
Now: Blue FZ6 Fazer
Old 03-11-11, 07:35 AM   #4
Dicky Ticker
Likewise with my Sprint,they tend to get brittle and break after a bit of time,inherent fault hence the recall. Being honest it took seven years before I had the problem but I replaced both---like for like for about a £10. A good bike service garage will have them as a stock item as the same fitting is used on several bikes
Old 03-11-11, 11:00 AM   #5
AndyBrad
a said the fuel tank fitting isnt part of the recall, just the male bit
Old 03-11-11, 01:35 PM   #6
Dicky Ticker
My error I thought it was the white plastic bit on the actual fuel line that had broken,as normally happens,not the female that it goes into
Old 03-11-11, 04:45 PM   #7
phi-dan
phi-dan's Avatar
Thanks guys.
Turns out the guy my mate bought it off had a second tank sat around, so he's bought that. Will probably get a new female connector to fix the current tank and recoup costs.
Now: Blue FZ6 Fazer
connector not connected mart SV Talk, Tuning & Tweaking 2 27-10-08 07:55 PM
Connector Rod - Help needed! Fraser SV Talk, Tuning & Tweaking 2 14-06-08 03:01 PM
Indicator connector MiniMac Stuff Wanted 3 07-06-08 04:59 PM
SV sidelight connector DarrenSV650S SV Talk, Tuning & Tweaking 2 04-07-07 10:47 PM
Can anyone identify this connector? cb9002 SV Talk, Tuning & Tweaking 6 14-06-07 10:39 PM
