Old 03-11-11, 11:06 AM   #1
-Ralph-
Default Triumph Owners - Have you fiddled with your ECU?
I know a couple of people on here have got TuneECU or TuneBoy and had a play, but given the number of Triumph/KTM/Aprilia owners on here nowadays, it's probably quite a minority?
I had a faulty connection to the O2 sensor on my Daytona which was causing some rough running and an MIL light on the clocks to stay permanently lit.
So I bought a 10 quid OBD2 to USB cable from ebay and downloaded a free copy of TuneECU, which allowed me to see the fault code to diagnose and fix the fault.
It also showed me that my fuel map was on version 10162, whereas the latest OEM version for my bike was 10180, so I loaded the new map with TuneECU.
There is a noticeable difference in torque and throttle response at low revs, and no noticeable difference in top end power.
Being a big capacity triple, the bike has always pulled well from low revs (3000 or so), but any urgency or power for an quick overtake needed 5000 revs or above, regardless of throttle opening. At this point with big throttle openings the engine note switches from the whine that the triple produces, into a growl and the bike romps off.
Now with the new map, it doesn't just pull from low revs, give it a handful and it growls and romps off straight away. I purposely went round a roundabout in third gear at 2000 revs, then gave it full throttle off the roundabout and up the dual carriageway. I was impressed. Not that I would ever ride it at 2000 revs anyway, it was an experiment, but previously it would have been open throttle and wait a few seconds for the revs to pick up.
Thought I'd post this because it's a really easy and cheap mod, and for me at least on a Daytona 955i, upgrading the ECU map from what it left the factory with, was a worthwhile modification.
Apparently if you apply custom maps, etc, you can get really big performance gains, but I'm not brave enough to do that and on a litre sports bike it's not needed.
I had to say to myself "feck it, I've got all winter to fix it if it screws up" before I did mine, as I was thinking 'ain't broke, don't fix it', but now I'm glad I did it.
Old 03-11-11, 11:11 AM   #2
dyzio
dyzio's Avatar
Default Re: Triumph Owners - Have you fiddled with your ECU?
Where did you get the new map from?
Old 03-11-11, 11:15 AM   #3
-Ralph-
Download from the TuneECU website
http://www.tomhamburg.net/Tune_List.html
Old 03-11-11, 11:18 AM   #4
-Ralph-
Also notice a big difference at higher speeds, so in lane 1 of the motorway at 5000 revs 6th gear, car in front moves to the left, crack open the throttle, much more responsive to the throttle, and pulls harder too.
Fuel consumption has suffered a bit, and it pops and bangs a little bit more on a neutral throttle or on the overrun, but that doesn't bother me.
I think it's just dumping a load more fuel in for a given throttle opening, but TuneECU won't read the original map, so I can't graphically see what the differences are.
Old 03-11-11, 12:06 PM   #5
AndyBrad
ive played about with mine quite a bit. the speed four is terrible around the 3k mark for fuling and with the standard can ive got the fueling spot on and it rides really really well. Ive also got a map for an open can but it doesnt run as nice imo with an open can.
ive got the tuneboy and tune ecu program. they are both excellent but beware, if you go adjusting things without knowing what your doing its quite easy to damage your engine!!!
triumph, aprillia, ktm owners AndyBrad Bikes - Talk & Issues 16 06-04-11 12:05 PM
Attention all Triumph Owners mattSV Bikes - Talk & Issues 8 12-02-11 12:45 AM
Triumph owners... the_lone_wolf Idle Banter 7 11-07-10 12:13 AM
Unofficial Triumph Owners Thread mattSV Bikes - Talk & Issues 69 29-05-10 09:09 PM
One for all the Triumph owners ... howardr Bikes - Talk & Issues 1 22-03-06 03:07 PM
