Old 10-11-11, 08:25 PM   #1
Tim in Belgium
Default Yamaha '04-'06 R1 - Anything to look out for?
So as the title suggest: Yamaha '04-'06 R1 - Anything to look out for?
I'm off to look at a few this weekend and was wondering if there is anything model specific to look out for?
Cheers,
Tim
Old 11-11-11, 04:29 PM   #2
Tim in Belgium
Default Re: Yamaha '04-'06 R1 - Anything to look out for?
Anyone on here got any info?
Old 11-11-11, 04:45 PM   #3
suzukigt380paul
Cheers,
Tim
aint got a r1 but would recomend a blade,any way go for a one owner never seen rain low milage fsh one that hasn't done track days or used as a wheely machine and you wont go far wrong,and then its down to condition
Old 11-11-11, 07:29 PM   #4
Tim in Belgium
R1 is the 'Ring weapon of choice, just ask the locals
Going for something lowish mileage, just wondering if there are any weak points.
Old 11-11-11, 08:52 PM   #5
neio79
The front end feel on all R1's is shocking. If you need confidence in that forget them. My 03 R1 was by far and away the worst handling bike i have ever had. Even after having the front set up for me and ktec new internals etc the feeling of it wanting to wash out was always there.
A friend has a 04 one and said the same about his version.
Old 11-11-11, 10:31 PM   #6
Tim in Belgium
Strangely this is the opposite to what my esteemed colleagues have said, interesting...
Old 12-11-11, 12:49 AM   #7
Lozzo
Neio speaks da troof.
R1 front ends are notoriously vague, the only one I ever rode that felt planted was a 2003 5PW model (letterbox rear light) that had Ohlins R+T forks fitted and an Ohlins shock. I'd say a Blade or GSXR K5 onwards would be a far better bike.
The R1 suffers from weak steering heads, they can oval the top bearing housing and I've seen three now with this problem. Also, gearboxes and clutches are weak, they all drink oil and top ends get noisy by 20K miles. CCTs give problems as do gearshift detent springs on up to 2002 models (easy fix if none of the bits fall into the gearbox). Body panels are very flimsy and crack easily. Exup valves stick and it's an expensive job if it's been left like that. There is a diagnostic function on the tacho needle that tells you when the valve is stuck - read an owners manual before you go to view so you know what's what. I've replaced four alternators on various model R1s in the past two years and that always takes the reg/rec with it.
Old 12-11-11, 08:19 AM   #8
Tim in Belgium
Thanks for that.
Old 12-11-11, 02:22 PM   #9
andreis
Tim
A-holes in cars?
Yamaha FZ1 Ward_650 For Sale - Other Bikes and General biking items 3 24-07-10 09:37 AM
Yamaha TDR 125 Girth For Sale - Other Bikes and General biking items 4 29-12-09 02:39 PM
Yamaha TDM 850 Tim in Belgium Bikes - Talk & Issues 13 13-11-08 12:58 PM
Yamaha R6 Steve H Bikes - Talk & Issues 34 17-07-07 10:36 PM
Yamaha air-bag wyrdness Bikes - Talk & Issues 5 04-06-06 07:34 PM
