Old 23-11-11, 12:40 AM   #1
Beetrootkiller
Default Speedo thingy for GSXR swap?
Okay so I bought all the parts I need for a front end swap today fitting them
Thursday.. Then remembers the wise words from here something about needing a speedo drive or something with some front end swaps..
The front end is from a K4 GSXR 1000 onto a K4 SV650S.
Basically I am in urgent need of knowing if I need a part or not and where to source it.. I need it fitted before I go back to work Monday!
Thanks for any help!
George
Old 23-11-11, 12:51 AM   #2
Default Re: Speedo thingy for GSXR swap!
Good luck
http://www.gregoryli.com/search/label/DIY
Old 23-11-11, 12:52 AM   #3
Some more linkys for you
http://uk.farnell.com/jsp/search/pro...sp?sku=1225630
http://www.leevalley.com/us/hardware...363,42348&ap=1
Old 23-11-11, 08:12 AM   #4
You need a Hall sensor and some magnets - have a search.
It can't be done by simply bolting up standard parts from either bike.
Old 23-11-11, 08:15 AM   #5
Beetrootkiller
Okay so if I've got this right it's as simple as.. Wire sensor into original wiring and mount to front wheel, put magnets in 4 cups nearby and mount.. Simple?
Old 23-11-11, 08:45 AM   #6
There are a number of ways to do, but that's the simplest. The last one I did, I made a bracket to fit the sensor inside the front mudguard, drilled a small hole near the top of the mudguard near the fork leg to bring the cable out, then ran the cable up with the brake line.
If I say it myeslf it's the neatest one I've seen. I have some pictures somewhere, I'll see if I can find them.
Old 23-11-11, 09:21 AM   #7
Beetrootkiller
Appreciate it!
So the magnets in their cup, you need four of them.. where do you mount them? Or is it better to make a mount for them and fit them in there then mount that?Thanks
Old 23-11-11, 07:26 PM   #8
Badeye
Default Re: Speedo thingy for GSXR swap?
I have thought about this swap but i don't want to lose my nice looking dash, would be interesting to see how someone else has mounted the hall sensor and magnets. Is the hall sensor easy to wire up?
Old 24-11-11, 12:13 AM   #9
Dead easy, connect the three wires from the new Hall sensor to the three wires that connected the original speedo drive.
The magnets are fitted into the recesses in the disc buttons.
Old 24-11-11, 12:29 AM   #10
Fatboy SV
Look on the site for acumen electronics. They do a kit which is complete and you can use your speedo!
gsxr/bandit oil filter wrench attachment thingy Quiff Wichard For Sale - Other Bikes and General biking items 2 01-06-10 09:46 AM
K3 speedo drive thingy Lozzo Stuff Wanted 2 28-02-08 04:14 PM
SV GSXR Fork Swap - Keep Stock GSXR Damper? Mesomorphman SV Talk, Tuning & Tweaking 5 08-09-06 07:40 PM
Really cool speedo solution for front end swap northwind SV Talk, Tuning & Tweaking 4 22-06-05 08:34 AM
