Old 23-11-11, 01:11 PM   #1
Epic Monkey
Default Power Commander and Fuel Injection Warning
Hey Guys,
So I bought a PCv and had my bike dyno'd and mapped at PDQ yesterday. It was running quite lean above 6k so they made some adjustments mostly to the higher range.
Took the bike home after and had no problems at all, bike was smooth and I could notice the difference.
HOWEVER, start her up this morning, and within 5 minutes of riding the red light on the dash comes up with the "FI" warning. I stop, turn bike off, turn back on and the warning disappears. This happened several times on my way to work. I haven't noticed any difference in the ride and it certainly doesn't feel like there is anything wrong.
I just called up PDQ to enquire what it could be and he's advised me to check the error code using the "Dealer Tool". They think it might be the lamda picking up the extra fueling and thinking there is a problem.
Since the error is not permanently on, can I ride with the Tool in place so that when the light comes on it will display the error code?
Thanks.
Old 23-11-11, 03:26 PM   #2
DJ123
DJ123's Avatar
Default Re: Power Commander and Fuel Injection Warning
at a guess is your bike a k6>
dealer tool plugs into the loom and will display fault codes on the dash. No need to ride with it in.
BMW F800ST
Old 23-11-11, 03:36 PM   #3
Epic Monkey
Hey daddyjob,
Mines a 2010, I'll try the dealer tool when I get home and see what comes up.
Thanks
Old 23-11-11, 03:39 PM   #4
SoulKiss
SoulKiss's Avatar
Originally Posted by Epic Monkey View Post
Hey daddyjob,
Thanks
Should just has someone re-map the stock ECU and saved the PC money...
Old 23-11-11, 05:59 PM   #5
SV650Racer
^ as above works perfectly fine on a road bike.
anyways you have it done now.
You need to either get it sds checked at a dealer or do it yourself to see what fault codes are comming up, if you get stuck with working out a code PM me. Using the dealer tool you have wont bring up stored codes though, only what the current showing code is. If you do it and the bike isnt fault coding then it wont show. The SDS software downloads every code that has occured, at what revs, temperature etc so is better for diagnosis.
Richening the fueling wont cause the fault code via the Lamda sensor. It is possible to bypass the lamda and remove it altogether and pin out the ecu so it no longer looks for the lamda. Thats something we do on bikes running full systems.
Old 23-11-11, 06:51 PM   #6
Epic Monkey
Thanks SV650Racer, I really appreciate the help. My ride home was fault free How typical - ask for help and then can't replicate the issue. The only thing I can think of that was different was the outside temperature this morning which was a lot colder than it is at the moment.
Talking about blocking out the lamda and pins on ECU, I was told by PDQ that they could not map anything in the 3-6k range due to the lamda and ECU overriding anything they map. Thinking I'll take a ride down to your shop sometime soon and have a chat.
Old 24-11-11, 09:16 AM   #7
SV650Racer
No probs. Outside temp wont cause an FI fault.
Also the lamda is a narrow band heated oxygen sensor, it doesnt run closed loop so only compensates a very small amount, not enough to effect the mapping. The PC5 works by interupting the signal from the ecu to the injectors, not the other way around so the ecu cant overide the signal once its been sent.
No probs pop by for a coffee and a chat..I can rattle on though so be aware LOL
Old 24-11-11, 09:38 AM   #8
SV650Racer
and btw Steve said if you bring the bike he will plug it into the SDS for free for you to see whats going on. Drop me a PM if you want to pop over and will confirm steve will be here.
Old 24-11-11, 10:35 AM   #9
Epic Monkey
That's very kind of you, thank you.
Power Commander, power increase? sephy666 SV Talk, Tuning & Tweaking 1 20-02-11 09:59 AM
Intermittent fi (fuel injection) warning trail guru SV Talk, Tuning & Tweaking 12 11-09-10 08:50 AM
power commander daddydan SV Talk, Tuning & Tweaking 30 16-05-08 10:01 AM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
Power Commander bobbydee SV Talk, Tuning & Tweaking 16 18-12-04 12:05 PM
